Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 04-21-2005, 02:07 PM
jdomner05 jdomner05 is offline
Send a message via AIM to jdomner05 Send a message via Yahoo to jdomner05
safe radio
i was trying to get my radio out of safe mode but when i hold mode and scan it just blinks safe it wont allow me to enter my code. I left the battery disconnected all night and it still wouldnt work. i really need some help because it is making me mad. please help
Old 04-21-2005, 03:58 PM
1.8 1.8 is offline
If it blinks, it means that somebody already punched the code in a couple times, but it wasn't the right one. For security purposes it doesn't let you punch it again. If you take the fuse out (which is located in the driver side fuse box) and put it back in again (It should be the last one on your right), that should reset the memory. If this doesn't work, leave your stereo on for like an hour or so cuz on diesel VWs, holding the scan and mode buttons doesn't do anything. You have to leave your stereo on for i think an hour, and then it will ask you to punch in your code! Give this a try anyway even if your car's not diesel and hopefully it will work!
Old 04-23-2005, 08:53 AM
Re: safe radio
Hey thanks for the advice, my radio is working again now and i have another question. The other day my fans stayed on and ran all day until my battery died. I got jumped off by a friend of mine but i was wondering if you or anyone knew why my fans kept running after i killed the engine.
Old 04-26-2005, 11:35 AM
boschmann boschmann is offline
Re: safe radio
The cooling fan module is common to fail (located under the round coolant expansion tank). Pull off the electrical connectors that attach from the bottom & see if there is corrosion leaking out from inside the module.
Old 04-30-2005, 08:58 AM
jjm106 jjm106 is offline
Radio in SAFE mode
I"ve read a xcouple of thewse message and it seems that the key is a 'code'. What is the code and how do I know where or what it is? Thanks. John M
Old 08-15-2005, 10:02 PM
malgal malgal is offline
Question
I also do not know what my code is. I was not given an owners manual when I purchased it. It is a 97 golf, and I know how to enter the code, but have no idea what mine is. Also once you enter the code, then what do you do? Any help would be wonderful, thanx
