| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
need some opinions
Ok, i will be buying 2 rockford P2's and a kenwood 2 channel 800w max amp, The subs will be running on 8G Wiring that has a 760 watt amp already running on it for my rear 6x9's
Am i going to be running into problems with my 8G wiring and having 2 Amps on it? And instead of the kenwood 800w (KAC-7251) i might get the kenwood 920w max amp (KAC-7202) would that be to much power running to the subs? |
Re: need some opinions
here is what i found out. the subs are 200wrms each. they are single 4 ohm vc and the amp ( go with the 7202) is putting out 150wrms x 2 at 4 ohms. not a lot of power but the setup will work fine. its all the p2s need anyway. you will probably need bigger wire. they probably both accept 8 guage so run a 4 off of the battery and split it to a couple of 8 guage wires.
(2) RE SX 15s (www.reaudio.com) ~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz) (2) eD Nine.1s (www.edesignaudio.com) 1 Optima yellow top (www.optimabatteries.com) 1 Optima red top 200 amp alt (www.dbelectrical.com) eDead V1SE2 250 sq ft Big 3 (1/0 awg) Pioneer DEH-P650 (www.pioneerelectronics.com) Infinity Reference 5 1/4 comps (www.infinitysystems.com Infinity Kappa 6x9s MTX Thunder 3404 Power Acoustik TFT/LCD Pyle DVD/CD/MP3/WAV/WMA player |
