Old 04-20-2005, 08:52 PM
webworks webworks is offline
Intake Manifold Runner Control (IMRC) ((SEE HOW TO FIX LINKAGE))
Ok... I have read the other items relating to IRMC issues...
This on e should be easy! I can see exactly what the problem is.
The linkage going between the control module and the bank 1 came off and little plastic doodad clip/keeper is gone!
This IRMC control was replaced a year ago and is not in warranty.
The dealer says they need to replace both the control and the butterfly assembly at a cost of $950
Ok so I am not even wanting to go there. I use this wonderful forum to locate what the problem is and a thread directs me to look at the linkages. I see one is not connected. The little plastic connector is missing where it connects to bank 1. The bank 1 butterfly rod moves freely and appears happy. I am thinking replace the plastic connector!
Another dealer takes a look and dig this. The dealer says they need to replace the entire IMRC control unit again at a whopping cost of $400.
They say that I can't buy the little 25 cent plastic connector and the only way to is to replace the unit!
Someone PLEASE tell me that Ford is not that lame.
Where can I buy the connector?
Respectfully,
Joe
Old 04-20-2005, 09:07 PM
bear_1961 bear_1961 is offline
Re: Intake Manifold Runner Control (IMRC)
The ford dealer sells the little plastic clips 4 for $20.00. Go to the parts dept. and talk to the counter guy. Tell him what you need, don't talk to the service guy, he wants to sell you service not parts. Good luck.
Respectfully,
Joe
Old 04-20-2005, 09:58 PM
wiswind wiswind is offline
I have read posts......where people have bought the plastic linkage parts from the FORD dealer....
Old 04-20-2005, 10:09 PM
Thanks!
I will go tomorrow and get some (I hope)
I will also make sure to get the part number for the item so in the future people can find them online!
Old 04-20-2005, 11:50 PM
road_rascal's Avatar
road_rascal road_rascal is offline
Send a message via Yahoo to road_rascal
Yeah, these IMRC's were a real brilliant design from Ford. I'd like to find the engineers to sat around and came up with that wonderful piece of work and beat them with an axe handle. My old '96 ate 3 of them (luckily I had an extended warranty). So far my '01 has been trouble free.
Does anyone know if the new Freestars use secondary intakes?
Old 04-21-2005, 09:57 AM
troopski troopski is offline
This is an argument for keeping any little piece of hardware that is left over from any project around the house. When I discovered that the clip disappeared on my 99 WS I clipped the back end off of a small plastic drywall anchor so I was left with just the "head" of the anchor. I shoved that in the hole and replaced the rod. It's been over two months and it's still there!
Old 04-21-2005, 10:00 AM
Thumbs up Re: Re: Intake Manifold Runner Control (IMRC)
Amen brother! You rock! Money not in their pocket is still in mine! What a great idea.
Old 04-21-2005, 12:14 PM
DUDE!
SWEEEEET
I spent an hour at the hardware store last night and did not find anything... maybe I will take a walk through the drywall isle
Old 04-21-2005, 03:15 PM
Imrc Linkage Fix With Pictures (DIY)
THE FIX THAT WORKED FOR MY 2000 WINDSTAR IMRC LINKAGE WITH PICTURES! (DIY)
Big thanks for the tip on the "Plastic Dry wall Screw Anchors" posted by "troopski"
OK first you are going to need to get the IMRC (Intake Manifold Runner Control) module off. I was able to remove the 3 bolts with an 8mm socket and extension. Then I managed to wiggle the module out and did not even have to remove the alternator or belt. It would probably make it easier if I had.
Next get a razor blade and lighter.
Use the razor blade to cut down the length of the dry wall fastener down to about 3/16" as seen below then use the lighter to carefully soften the edges of the fastener and tilt them in a little so they will help to lock on the linkage rod.
I decided to use a dab of JB Weld so the new peaces I made will not pull out of their square mounting holes. Be careful not to get the JB Weld inside surfaces of the new peaces that will contact the rod. Mount all 4 of your new linkage connectors and let the JB Weld do it's thing (what ever the instructions say for the appropriate hardening time.) If you do not use JB Weld make sure the heat rating of what ever you use can deal with the engine compartment temps!
REMEMBER JB WELD IS AMAZINGLY DURABLE SO DON'T GO CRAZY USING IT YOU MIGHT HAVE TROUBLE GETTING IT OFF IF YOU SHOULD EVER HAVE TO!
Now that the JB Weld is hardened/cured... go ahead and re-assemble the linkages and install the control module.
I put a little graphite on the contact surfaces where the plastic and linkage rods touch.
You will need to be creative to to get it all snapped together (needle nose pliers and a screwdriver helped me poke things back together).
I put a little graphite (dry lubricant) on the surfaces where the plastic and linkage rods contact.
It was not all that difficult.
Best of luck and thanks to everyone on this forum that had input!
Old 04-25-2005, 12:46 PM
Post Actuator Bushing Part#
The FORD part number for the bushing that is on the IMRC actuator rod is
F5RZ-9F955-AB . There is only one per pack.
www.y2kford.com/default.aspx?html=parts.html
Part Number Search Results : OEM Catalog Item NumberListCore PricePriceF5RZ9F955AB$5.82$0.00$4.12
RETAINER-ENGINE THRO Add to Cart Contact Us
This price is plus shipping.
***I do not work for y2kFord in any capacity nor do I endorse them. I just have found that they generally have the lowest price on genuine FORD parts. Usually 50% less than my local FORD dealers. Best of luck with your repairs.
Old 04-26-2005, 12:53 PM
Imrc Actuator Part Number
Just in case anyone needs the part number for a 2000 windstar IMRC Actuator
XF229559AA because the parts people at ford have no clue...
Old 04-29-2005, 12:27 PM
dandi dandi is offline
So - what exactly do these clips do? My '99 is in the shop getting the CEL checked out, and I was told that these clips needed to be replaced. Being that we are heading to Washington DC tomorrow am, I told him to go ahead. Cost is $180 (including an oil change). But I'm wondering about the actual function of these clips...?
Thx, Dan
Old 04-29-2005, 12:54 PM
12Ounce 12Ounce is offline
The "bushings", "clips", etc ...are also "retainers", and when they fail, the linkages from the actuator motor to the IMRC itself just fall out of place ... usually jamming everthing up.
I think the Ford replacement parts must have been upgraded in material because I've got a 100k miles or more since replacement.
Old 04-29-2005, 01:29 PM
Interesting, well our van was running okay even though these clips needed replacing.... Does that make sense? It sounds like, from your description, we should have had some running issues but it ran as "well" as it normally does.... ;-)
Dan D
Old 04-29-2005, 04:07 PM
Re: Re: Re: Intake Manifold Runner Control (IMRC)
If these clips break (which they do easily) it will effect your idle and can effect yor mileage. It "WILL" run seemingly fine without them but it will effect your mileage and top end power.
Dan D
