Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-20-2005, 07:50 PM
Olona Olona is offline
Unhappy Ignition Coil - need help
I checked coil for voltage and I am getting a weak spark. Could this be a bad coil?
Old 04-20-2005, 08:09 PM
Dale Aeppli Dale Aeppli is offline
Re: Ignition Coil - need help
year and engine what are trying to find out dale
Old 04-20-2005, 08:14 PM
Re: Re: Ignition Coil - need help
Sorry, 94 gc, 4.0, Jeep will not start, I replaced CPS, and it is getting fuel
Old 04-20-2005, 08:32 PM
Re: Re: Re: Ignition Coil - need help
Did you check for spark at the coil wire since you changed the CPS sensor Dale [email protected]
Old 04-21-2005, 02:42 AM
mx52nv's Avatar
mx52nv mx52nv is offline
Also check all of your fuses(especially the tiny ones) and camshaft/return pickup sensor.
current rides:
1990 Turbo Miata
lifted and locked 96 Grand Cherokee with other toys under the hood
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Your SUV isn't a Jeep, and my Jeep isn't an SUV....
SCCA, where you actually learn to drive
Old 04-21-2005, 11:32 AM
jamesbong jamesbong is offline
I just had the same problem. Check the secondary resistance of the coil between any of the input terminals, and the output terminal. If it's out of range (11.5k to 13k ohms roughly) then replace it. Mine was reading 10k, and the jeep wouldn't start. These coils are weak to begin with, so even a little out of tolerance is a bad thing.
Old 04-21-2005, 12:39 PM
Checked coil for OHMS and got a 9 so I will replace coil next. Thanks, hope it works.
Old 04-21-2005, 01:12 PM
mx52nv's Avatar
You should have just replaced it anyway, your Jeep is 11 years old.
current rides:
1990 Turbo Miata
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Old 04-21-2005, 01:16 PM
Replaced coil, and it cranked right up, Thanks to you all
