Old 04-20-2005, 07:24 PM
98SilvyKid's Avatar
98SilvyKid 98SilvyKid is offline
Send a message via AIM to 98SilvyKid
Service Engine Light
The service engine light in my 98 K1500 won't seem to shut off. All fluids check out well, and the oil is still pretty clean since it was serviced around 1500 miles ago. Any ideas? Thanks for any help guys.
1998 Chevy K1500 Standard Cab, Flareside Cargo Box,
All Options, 5.0L V8, 4L60E -K&N Filter, Custom Exhaust, American Racing Rims, Manik Brushguard, CF Light Shades, Glasscapes picture, More to Come!
Old 04-20-2005, 07:38 PM
2000CAYukon 2000CAYukon is offline
Re: Service Engine Light
If the SES light is on, there is a code stored and you need a scan tool/code reader to get the code. From there you can determine what is setting the code.
//2000CAYukon
Old 04-20-2005, 09:17 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Take it to auto zone or advanced auto and they will let you scan it for free.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
HD chassis package
Old 04-21-2005, 09:55 AM
benw benw is offline
if you are tired of the light always being on then you could just pull the bulb like I did
Siverado's are one of a kind. 252,000 miles and counting.
Old 04-21-2005, 01:25 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Re: Service Engine Light
Not a good idea. Depending on what state you live in and their emission laws, doing such a thing can be grounds for an immediate failure in your inspection. Many state are now, in the effort to clean the air, are passing very strict emission laws. The federal government is also trying to coax other states into doing the same. Some states, like NY where i live have adpoted new emission laws whereas when you bring your vehicle in for it's yearly inspection, the first thing they look at is the MIL or SES light. If that is illuminated you fail, if it doesn't light up when you start the vehicle, you fail as well. So if you in some way disable the light, it will cost you to have it repaired so it is in working order.Some people try to fool the system by going to an auto parts store that reads your codes for free, and have them clear the codes. When you bring your vehicle in. it is hooked to a computer that scans the system and if it sees that the sensors have not run long enough to do their tests and register anything, you fail the test and are required to bring the vehicle back after you have driven it enough to "ready the system." So in the long run it might be more cost effective to get the SES light checked out to see what the problem is, who knows it might be a cheap and easy fix?
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 04-22-2005, 08:03 AM
Riche Riche is offline
Louisiana scans the computer for trouble codes. I have seen someone pull the bulb and still not pass b/c the computer doesn't lie!!!!
Old 04-22-2005, 06:22 PM
98SilvyKid's Avatar
Thanks for the help guys. I eventually want to get a scanner for myself but there so expensive.
Old 04-22-2005, 10:20 PM
TaNK_Em's Avatar
TaNK_Em TaNK_Em is offline
Send a message via AIM to TaNK_Em Send a message via MSN to TaNK_Em Send a message via Yahoo to TaNK_Em
Dont waste your money on a scanner, You only need one if your going to professinaly work on cars and whatnot not for home use. Go to AutoZone (Or insert other shop there) and have them read it.
- Kevin
May God have mercy upon my enemies, because I won't.
- General George Patton Jr
Old 04-22-2005, 10:26 PM
- Kevin
The only problem with that is that most of these places that do it for free can't scan ABS codes, only the engine/ emission codes.
Old 04-23-2005, 08:31 AM
98SilvyKid's Avatar
Working on vehicles myself is what I have in mind though. My father and I want to start working our vehicles oursleves to save money. We really need to do this, since all the mechs around here are too expensive. My father has a 1994 and I have a 1998, that's the only problem. We need a scanner for both. We could easily spend 100 bucks on one though. I'm saving up...
Old 04-23-2005, 12:39 PM
skipr skipr is offline
A Vetronix Mastertech cost around $6000.00, lower end scanner is going to be over $500 for a decent one.1994 you can retrieve codes by putting a jumper wire in the "A" terminal and "GRND" (dianostic connector).
Old 04-23-2005, 06:07 PM
98SilvyKid's Avatar
What about an Actron AutoScanner? There some for around 100 dollars depending on the model and it's accessories.
Old 04-23-2005, 06:44 PM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
The things you can do with those $100 scanners is extremly limited. Look at the very vague information "Twilightzone" will give you when they read it for you. Honostly, do you think each Autozone store invest in those $6000 scanners? Do you really think the geniuses behind the counter really know how to use them? If they did know how to utilize the information one of the more expensive scanners, then why in the world are they behind the counter selling $#*^ parts to people??? Think about it......
Old 04-23-2005, 09:52 PM
/\ /\ Maybe your Autozones are different from the ones in my area. We have a lot of great counterpeople who know how to use the scanners, and decipher the codes to help the customers solve their vehicle's problems. Sure some stores may have employees who aren't the best suited to use one, but I have seen many garages that have similar help who can't understand what the codes mean and end up just replacing random parts in an effort to solve the problem, thus costing the customer more money than it should. These lower end scanners are a good tool for the DIYer to at least give an idea of the problem and then the user can do some research, either online, or a repair manual to try to correct the problem themselves. But like Tank'em said in an earlier post. If you have a place that does it for free, save the money and have it checked there. If anything, you'll leave the store with the code(s) that came up and you can research it on your own to find a fix.
