Idle problem
Ok here it is. I replaced the KLZE engine in my 93 because it locked up. It ran like a top until this happened. The engine I replaced it with ran great but when left to idle would stall. You then had to turn the key the whole way to off wait a few seconds and start it again. When I put this in my car I replaced all the sensors with the ones from my old engine. The only thing I did not replace was the EGR valve. The engine runs great but when left to idle it now idles up and down and sometimes just stalls. I no longer have to turn the key off again before starting. I used my old intake and replaced all gaskets. I am clueless here to what can be causing this. Anyone have any thoughts????????? I am up for trying anything!!!!!!!!!!
Denny |
it sounds like it could be your mass air flow try that same thing happend to me. test your battery it sounds weird but i had a bad battery and my car had a wierd idle and my car stailed on me try it
Re: Idle problem
Well i hope it works out my probe is acting funny too . but i just replaced the battery and it fixed it. i was idleing really low and then i had a bad battery. what does 2.0 probes idle at mine idles and the bettween frist and sec line above 0
Re: Re: Idle problem
Re: Idle problem
Well problem fixed. Not sure what it was, I pulled the intake replaced a few hard vacum lines plugged the EGR valve and siliconed the intake gaskets. The vehicle runs like new again with loads of power. |
Re: Idle problem
What did you do to plug the EGR... I had a blazer that i made a plate to eliminate the egr but the the truck ran eaven worce...... My probe 2.0 is doing the same thing yours was minus the stalling... and im thinking its the egr, and my power band seems to drop off at about 3800-4000 rpm as well.
