Old 04-20-2005, 05:16 PM
Cait Sith Cat Cait Sith Cat is offline
Send a message via AIM to Cait Sith Cat
Mudding witha 2wd?
When I told my friend I have a 300 I6, he said it rocked and that I should get All terrain T/As and take it to the mud. I asked him if I cold do that with an auto 2wd, and he said yes.
I thought I'd get a second opinion on this...
1994 F-150 XLT 4x4 ext. cab 5.0
R.I.P. '96 300, may those dirty mechanics burn in hell.
Old 04-20-2005, 05:40 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Mudding witha 2wd?
I would not recemend taking it mudding. That is just asking for trouble. The only two wheel drive car you should take in the mud would be something like a sand rail.
Old 04-21-2005, 07:33 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
you could if you want, it all depends on how much you value your truck. i know i wouldnt and i have an 300 I-6, it has nothing to do with the engine anyway. It all in the rear-end, and if that truck of yours is stock or close to stock, you most likely dont have posi.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 04-23-2005, 10:59 AM
Thank FTO, I had my worries about taking his advice..
Positrack is where both wheels turn at the same time, right? why don't they have that on all vehicles?
Old 04-23-2005, 05:11 PM
tturnpaw's Avatar
tturnpaw tturnpaw is offline
Send a message via AIM to tturnpaw Send a message via MSN to tturnpaw
Yes. Its cheaper to produce cars without it.
1982 Mustang GT- roller motor x303 cam, GT40s, MAC/Spintech exhaust MSD ignition, Edelbrock Carb, Ford Racing roller rockers
1994 Escort 2DR LX - cone air, 3.8L throttle body, FUTURE SPI turbo swap
Cops: You can race, but Im impossible to chase!
LS WHAT?
Old 04-23-2005, 08:25 PM
tturnpaw is exactly right, most car manufactures try to save as much money when making cars as they can.. now i think some off-road and the SVT packages come with posi, but you pay the differance in $$$.
'95 Ford F-150
Ford Racing Pride
General Motors who?
Old 04-25-2005, 07:56 AM
Oscuro Oscuro is offline
Send a message via MSN to Oscuro
Cost and....Drivability:
Posis and Limited Slips in general can make the occasional noise as they engage and disengage their clutchpacks or other systems. Also, clutchpack using limited slips require special gearlube additives to keep the clutches working properly. If the lockup is solid on a limited slip diff, you can also have slightly more trouble going around corners as the outside wheel needs to spin faster than the inside; if the diff doesn't let them rotate freely, they can bind and sometimes squeak a tire.
Besides: In 95% of daily life, you don't need posi-traction, limited slip diffs or other forms of such mechanical traction aid. So why bother with the added expense and maintenace from the factory?
On the mudding part: It isn't advised if you have an open diff. However, if you do decide to try it, there are a few things I need to suggest: Make sure you have a friend with a second vehicle there,
Keep your revs up, and use speed to get through the mud,
If you do get bogged down, do NOT sit and floor it repeatedly: You'll just overheat your engine, transmission, and axle. Get help to pull you out.
And mount strong friggin tow hooks to your frame. Bolt them on using Grade 8 bolts, and preferably an 1/8 inch piece of bracing plate on the opposide side of the frame (sandwich the frame between the tow hook and the plate). The reason I suggest the bracing plate of steel, is so that if you do need to use the tow hooks, there is much less risk of them warping your frame, and it provides an even stronger mounting point (useful for hauling 2000+ pounds of mired truck). If you can, mount 4, two at each end. If not, 2 at the minimum, one in front, one in the rear.
This is so that someone doesn't stupidly attach a tow strap to your truck's front suspension or rear axle, and potentially damage your truck.
Old 04-28-2005, 04:11 AM
highboy73 highboy73 is offline
see folks mudding the 2wd's all the time,most of them are drunk and in the process of blowing up the motor.go have some fun just don't do anything dumb that would tear up your truck.
as for the posi....corners and ice one time in a posi equipped car or truck and you'll see why they don't put them on everything.
Old 04-28-2005, 02:19 PM
Thats also why you dont drive on ice in the first place. And most people, if they do, drive in 4wd. Plenty of cars have posi, and with out it, on ice both wheels would spin regardless.
'95 Ford F-150
Ford Racing Pride
General Motors who?
Old 04-29-2005, 08:57 PM
so from what you say when it snows or sleets the only people out driving have 4wd?and how can you help but not drive on ice when it's all over the road?
when you have a posi both tires spin at the same rate right?and when it's dry or you can get suitable traction it will let the one tire slip as you turn a corner right?well here where we live we gets lots of snow and ice and when you go around a corner in an open diff car or truck,normal driving of course,only one tire is getting power so you can turn the corner with out the rear sliding out.now with the posi rear both tires are spinng the same speed and there isn't sufficent traction for the the posi to slip the one tire so the rear slides.wheter you are doing 15 or 50 mph.
most 4x4 aren't 4wd drive any way,they might have a rear locker in some(factory)but not in the front.factory that is.
Old 04-30-2005, 08:15 PM
fcl01 fcl01 is offline
with a limited slip and good tires, a good driver can go places in 2wd that an idiot with no skill and 4wd cant even think about going. i still wouldnt recommend muddin in a 2wd unless there's someone there to pull ya out.
Old 05-01-2005, 04:43 PM
Highboy, When you take a turn on ice, BOTH tires will spin, its happened to me and i bet its happened to half the people here. I didnt say that you couldnt drive around in a 2wd in the snow and ice. but if you seriuously wanna see the results of a 2wd in snow and ice take a look: http://media.ebaumsworld.com/index.p...ercarslide.wmv
Now, if you still wanna argue the point, go ahead but your wrong.
'95 Ford F-150
Ford Racing Pride
General Motors who?
Old 05-02-2005, 10:54 AM
don't think you read my post good enuff.no i am not wrong about the way they both function.and i'm sure if you knew half as much as you thought you would know that.so if you want to argue please educate yourself with the way a rear axle functions please.
what does that vid clip have to do with a rear wheel drive car turning a corner?and all them were front wheel drive also.which of course doesn't have an axle like a rwd.
If you think you can do a thing or think you can't do a thing, you're right.
Henry Ford
Old 05-02-2005, 04:52 PM
It was the point, and i dont appriciate being called down on what i do know. I wouldnt be posting if i didnt. If you wanna still call me down on it thats fine, but you need to take it somewhere else. Ive slipped around in a non-posi axle before on wet pavement. Most have, i know on dry pavement i cant spin both but on ice, its more than clausable. To the result of only one tire spinning on ice, you must have one heavy ass vehicle. Every time ive ever taken a corner with ice on it, both tires have spun, its the slick ice thats letting it not your rear axle.
'95 Ford F-150
Ford Racing Pride
General Motors who?
Old 05-02-2005, 04:55 PM
Now can we please get off this subject, Its not even about mudding with a 2wd anymore.
'95 Ford F-150
Ford Racing Pride
General Motors who?
