Old 04-20-2005, 03:57 PM
Stealth-Twinturbo Stealth-Twinturbo is offline
Spark Plug Gap
I always heard you need to regap your plugs to prevent spark blow. I regapped to .036 is that where i should be? Or should i have them gapped lower.
92 Stealth R/T TT
CURRENT MODS:
K&N FIPK
Spec Stage 3 Clutch 6 Puck
HKS Turbo Timer Type-1
3 Inch Polished Y-Pipe
Greddy Profec B Spec II @ 12.0psi
Greddy Type S BOV
Greddy Catch Can
Borla Exhaust
3 Inch SS Down Pipe with Race Pipe
3SX Crank Pulley
Accel 8.0mm Wires
Gen 3 Lifters
High Flow 290lph Fuel Pump (Supra Pump)
Plugs Gapped at .030 Iridium IK20's
550cc RC Engineering
Apexi S-AFC II (WILL BE REMOVED NOT YET)
2 G-16 Turbos
AEM EMS
FUTURE MODS:
Custom FMIC
Old 04-20-2005, 06:23 PM
Gateway's Avatar
Gateway Gateway is offline
Re: Spark Plug Gap
Q: What should I set my spark plug gap to?
A: The stock spark plug gap is between 0.039 to 0.043 in. The plug gap should be decreased to between 0.028 and 0.034 in. for running higher than stock boost levels. Ideally, you should use the largest gap that does not create spark blowout with the boost setting you use.
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 04-20-2005, 07:00 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: Spark Plug Gap
I did .34 and I think thats what most people who raise the boost up to 14 have theirs at, I did it in anticipation of raising the boost. It works fine, a hell of a lot better than .45 (the gap if the plugs installed when I got the car).
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 04-20-2005, 07:40 PM
Igovert500's Avatar
blue + red light magnet
Re: Spark Plug Gap
if you aren't getting blowout...there is no reason to lower the gap.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
