| Off-Topic Talk about anything other than cars. |
my car is hard to shift and the petal is acting up, when i slow down it want to go down. its a brand new master cylinder, it worked fine untill i smoked my clutch. would this have anything to do with the clutch?
thanks
-1995 Eagle Talon TSI AWD -5 speed -evo 3 GT -SAFC 2 -NGK Plugs -walbro 255 fuel pump -550cc injectors -pocketlogger -2.5 full exhaust (no cat) -30 psi bov |
Re: crank walk i think
Being hard to shift has never been something I have heard related to CW. The best thing to do, if you are concerned, is measure the endplay in the crank. You can do this fairly easily.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
It could, did you replace all the internels in the trany? Like the fork? Things like that. I don't think it is crank walk. That is really not what happens if it was. Maybe try bleeding the mas better.
98 MITSU GST, 1990 TURBO MOTOR 98 ACURA INTEGRA LS 88 HONDA CIVIC HB 97 HONDA CBR 600 91 HONDA CRX DX 89 JEEP ![]() ![]()
ive bleed it several diffrent times, maybe its defected master, the first one i put on sucked to the floor, then i got this one and it worked fine for awile then i smoked the clutch and right after that it started doing it.
get 2 friend. read the vfaq and bleed the clutch right.
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
its bleed right i know how to bleed so thats not the problem
try replacing the master before going and tearing apart the whole motor just because you THINK it's crankwalk.
Measure the crank endplay!!!
