Old 04-20-2005, 11:40 AM
biglogonafrogbig biglogonafrogbig is offline
Changing Wheel and Tire size
I'm going to change to a bigger tire and wheel nothing huge just a little bit bigger. Someone told me when you do this it will mess up your transmission and engine will be running difrent and of course the speedometer would be messed up, my question is can they reprogram the computer to allow for the bigger tires on an 88 silverado thanks for the help
Old 04-20-2005, 02:14 PM
abaird abaird is offline
Re: Changing Wheel and Tire size
Most power programmers allow you to adjust for bigger tires. I wouldn't worry about it though. All it will mess up is your speedo and probably not very much unless you go from 27" tires to 35" tires.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 04-20-2005, 09:26 PM
caveman87 caveman87 is offline
how big are you talking? that makes a difference unless you go to 35's or bigger then it depends on what you do. do you mud? rock? or city drive
Old 06-03-2005, 01:06 AM
sub006 sub006 is offline
You're in luck with your '88, I think this is one of the last years for the mechanical speedometer. A gear change for a few bucks will correct your indicated speed.
I have a '90 which I think is the first year for the %$&#@! electronic speedo. The only way to alter its reading is to change a printed circuit in the dash which costs well over $100 for the part alone!
Old 06-03-2005, 03:16 PM
broughy84's Avatar
broughy84 broughy84 is offline
sorry your wrong, an 88 has the electronic speedometer.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 06-06-2005, 03:40 AM
Cam7 Cam7 is offline
I just picked up a 88 Stepside 350 4x4 with 33 in Tires. Havent had any experience with that big of tire for everyday driving. I know it wouldnt tow at all at speeds over 40 mph. Dont know if I should stay with these or go back to a stock tire? Will be using for Towing.
