Old 04-20-2005, 10:57 AM
butcher123 butcher123 is offline
amp or amps
good ay guys, ok well im want to know how many amps im going to need. i want to run all my speaker and subs but im having trouble understanding the amps. Ok well i have two 4" in the front, and two 6x9" in the back also in the back are two 10" subs and a 12"sub for show. It all looks good but i would like to get them all working. I have one amp so far and it a 4 channel amp. Is this amp enough to run all of the speakers and subs or will i need another amp, if so what type 2/3/4 channel, and what setup would sound best. Thanks
Old 04-20-2005, 01:53 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: amp or amps
depends on how much you want to spend, but i sugguest you use the four channel for the four speakers, get two more amps for the subs, one one channel for the 12" and one two channel for the two 10"s.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 04-20-2005, 02:15 PM
germanyt germanyt is offline
Re: amp or amps
4 channel for the mids and highs. ditch the 12 unless it is the exact same as the tens (make and model). you will probably want to have them sealed too. if the subs are not the same, you will not get very good sq. that is my experience. i thought about running my infinitys and my p3s together but they are just too different and i wouldnt get nearly the result of 4 of the same 12" so i decided not to do it.
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
Old 04-20-2005, 02:20 PM
bjboertje's Avatar
Re: amp or amps
i would keep all the subs, just have different amps for the 10s and 12s.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 04-20-2005, 02:23 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: amp or amps
What is with noobs obsessions with having multiple subs of different sizes or mixing brands...
DON'T DO IT!! Period...
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 04-20-2005, 02:29 PM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
Re: amp or amps
mixed subs sound like crap in every sytem ive heard them in.stick with ATLEAST the same producer [JL Audio pioneer alpine etc.] if not the model.
Old 04-20-2005, 10:10 PM
um well the subs i have are all kenwoods, so im not mixing different brands. So should i go get two more amps as well as the 4 channel one i have. my friends selling a 2 channel kenwood amp would if be good if i buy it for the two 10" subs. On another forum, a guy said i should hook the two subs and the 4" on the amp i have and run the 6x9 off the deck. Is this a good idea? Also when i have multiple amps, do i have to install multiple cables from the battery to the amp or can i join it to the previous amp. Thanks
Old 04-20-2005, 11:07 PM
Re: amp or amps
you can use the same power wire up to the amps but the main wire off the battery will need to be big enough to carry the power. once to get to the amps you will need to split the cable. (i dont mean unstrand it) buy a splitter. im not sure if you know what one is so ill explain, if you have 0/1 awg wire off the battery you will need to split it to 2 4 guage, double 0/1 to 2 2 awg wires, 4 awg to 2 8 awg wires and so on. and i would recommend getting new amps for the subs and keeping the 4 channel for the mids and highs. i dont know how much money you have to spend so if you cant get the extra amp im sure the other guys in here can help you wire it to get the best performance using two amps.
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
