Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-20-2005, 10:40 AM
MosquitoFogger MosquitoFogger is offline
Sudden oil burning
I just bought a nice clean '93 Civic DX with 88,000 miles. Before buying it, I took it to a well known Honda specialist to have a pre-sale check done. The results were that it had a slight oil pan gasket leak and it needed plugs. Otherwise, it checked out fine. Took it home and put new plugs in. The old ones looked great (tan powdery residue), just like they should if the car was running good but the gap was burned out a little. Now it's burned 3 quarts of oil in about 400 miles. Any ideas what would make it suddenly burn a lot of oil?
Old 04-20-2005, 12:08 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Sudden oil burning
burned or leaked ?
Team Lonely Drivers
Old 04-20-2005, 12:27 PM
Re: Re: Sudden oil burning
Originally Posted by civickiller
burned or leaked ?
Definitely burning it. Blue smoke on acceleration. No wetness at all underneath.
Old 04-20-2005, 01:46 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
if your losing three quarts of oil to every 400 miles, you should definately have an oil puddle somewhere. if your burning it, there should be alot of smoke coming out of your pipe.
compression test if its coming out the pipe.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 04-21-2005, 02:41 PM
Just came back from running a compression test. 185 lbs. in all four cylinders with excellent leakdown. Any ideas? Anyone?
Old 04-21-2005, 02:57 PM
Skyline_BNR34's Avatar
Skyline_BNR34 Skyline_BNR34 is offline
Registered User
Piston rings are probaly fried and need new ones. Take it to some guy and have him rip apart the motor and see whats wrong...
Old 04-21-2005, 04:36 PM
AF - Advisor
Re: Re: Re: Sudden oil burning
if your losing 3 quarts to every 400 miles, that oil is going somewhere. it cant magically disappear. your burning it, or, your leaking it.
3 quarts is alot of oil. 185 across the board is good. im assuming your cylinder leakdowns are less than 10% hence the excellent and assuming the compression and leakdown was properly done. no inconsistencies with the leakdown?
losing three quarts of oil with a good compression, leakdown, and no puddles or signs of oil leakage = makes no sense.
Old 04-21-2005, 05:47 PM
Re: Re: Re: Re: Sudden oil burning
You may have missed my earlier post where I stated it's definitely burning it. It's blowing blue smoke and has oil film on the back of the car around the tailpipe.
Leakdowns were consistent 4-5% and done by a Honda specialist. I have an extensive engine building and racing background but this is the first Honda I've owned. Like yourself, I DO (unlike some people posting here) know what the results of a compression test mean. I pulled the air inlet hose and found that the breather tube from the valve cover has been spraying oil into the intake, so I'm going to investigate crankcase ventilation
Tell me about it. That's why I'm posting. I'm hoping someone knows of a likely cause. And I appreciate your input.
Old 04-21-2005, 07:26 PM
valve stem seals ?
Team Lonely Drivers
