Old 04-20-2005, 09:44 AM
sherman69 sherman69 is offline
Fuel pump opinions wanted
Hi,
On a 97 K1500,
My 2 year old fuel pump just died. No whirring noise at all.
Therer is a small spark when I hook up the 12 volt wire to the test jumper which shows it is a complete circuit, but the pump fails to run and no pressure.
First,
There are several brands and a lot several opinions,
What brand do you guys reccommend? I'd really love it if it runs a lot longer than this one did. This was from NAPA and I believe it would be Carter.
I've seen AC Delco,Airtex (which the tow truck driver likes), Bosch (Autozone) and now Delphi which I lean toward because I believe they have replace Delco as factory parts, and maybe have some reliability.
Second.
I think I'm going to lift the bed rather than drop the 3/4 full tank.
So there are 4-6 bolts and wire to the lights/trailer plugs, I also have a fifth wheel hitch so there are another 4-8 bolts. Am I missing anything?
Thanks for any thoughts,
Old 04-20-2005, 10:50 AM
benw benw is offline
I would definetly take the bed off. When I replaced the pump on my '94 there were eight bolts and dont forget about the filler neck and tail lights. Depending on your facillities you may be able to just slide the bed back about three or four feet like I did.
Siverado's are one of a kind. 252,000 miles and counting.
Old 04-20-2005, 06:08 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Re: Fuel pump opinions wanted
I would say get what came from factory, OEM AC Delco, $285-350 depending on where you get it. If i were you i would spyhon most of the gas out of the tank and then remove the tank. I have dropped the tank when i replaced my pump and when my buddys went bad we removed the bed on his. Dropping the tank took about an hour and a lot of aggrivation less.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 04-20-2005, 10:34 PM
localyokel localyokel is offline
Hi, I like delco pumps #1 quality #2 comes w/ extra stuff like connectors wires new rubber (important)all of which you should use!As far as I'm aware other brands just supply the necessities. The bolts that hold the bed on were extremely tough comin out for the first time.I also didnt take the shell off the bed which made it more difficult(took 6 people).I suppose if you have good equipment and ways + means to get the bed off thats the way to go.If not just drop the tank. Good Luck!!!
Old 04-20-2005, 11:03 PM
J-Ri's Avatar
J-Ri J-Ri is offline
The bed bolts can be very difficult to get off. I had to take the bed off a ranger (driveshaft had to be removed to drop the tank, and the u-joint bolts were rounded off), and it took about 10 minutes per bolt with a 1/2 inch impact and 2 bottles of penetrating oil.
I'd definately drop the tank unless your truck is nearly rust free. The tank's not really that bad to drop, just use a 2-by and a floor jack to lower it
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-21-2005, 09:25 AM
OK,
Obviously dropping the tank would be a lot less unscrewing bolts. But it's long and 3/4 full. I'd hate to have it slip off the floor jack.
I've got the 8 bed bolts out along with 4 of the 8 that hold the fifth wheel hitch on.
I'm in California so NO rust. The bolts needed a breaker bar first, then the ratchet did it fine.
I think I'll add antiseize when reassembling so it comes off even easier next time.
Waiting for a friend to help lift tthe tub today.
BTW, I'm still torn between what brand pump to buy.
I wonder if the california gas is causing some of the pump failures. I recall som problems with plastic in fuel systems failing. AND, My pressure guage release button swelled and bound up last year so I replaced it.
I see Delphi as a factory part now and wonder if a newer approach will be longer lasting?
Otherwise it will be Delco.
Bob B
Old 04-21-2005, 10:30 AM
Wheeler88's Avatar
Wheeler88 Wheeler88 is offline
Don't forget besides those bed bolts to disconnect the tail lights, filler neck, ground wire and vent tube.
88' Chevy K1500 Silverado
350 V8 5.7
Original Owner
77,000 miles
2nd tranny
Peeling Paint - Defective Factory Paint
235/85/16 BFG MT
Old 04-21-2005, 01:23 PM
Sounds like the hard parts over.I was able to move the bed back far enough like benw mentioned previously.Set the front part of the bed on rear tires and rear part on bumper.(std cab long bed)hope this works for you as well!
Old 04-22-2005, 08:39 PM
bracketshark bracketshark is offline
Re: Re: Fuel pump opinions wanted
I bought my 97 c-1500 pump from GM, it listed for $145, my price was $90
Old 04-26-2005, 11:21 AM
fixed it
Thanks for the help guys.
Ok so I replaced the fuel pump with a Delphi. The new factory supplier.
Cost 88.00. My local NAPA was able to order it through a new catalog.
I wouldn't use Carter again as the old one was 1 1/2 years old.
I cut the old one apart and found it was frozen so it looks like it got too hot. Even some melted plastic.That's a real thrill knowing it is inside the fuel tank. The carter was from NAPA not local though. And had a one year guarantee, but I can't find the receipt. plus it is nw 1 1/2 yrs.
This thing started to act up before it was a year old. I even started carrrying the pressure gauge with me to try to catch the reason for hard starting. It always started to work by the time my brain told me to hook up the gauge. Finally failed totally on the road 120 miles from home.
BTW, I did lift the bed, but next time I will buy a syphon and rent or buy a tranny jack.
My truck has a fifth wheel hitch so that added 8 bolts on the hitch to frame I needed to remove ( no real problem thought because I live in No rust California.
But the wiring for the hitch doesnt have a plug and was not quite long enough to really pull the bed and I didn't feel like cutting the wires.
Bob B
Old 04-27-2005, 07:13 PM
big_blue_chevy2006 big_blue_chevy2006 is offline
Send a message via MSN to big_blue_chevy2006 Send a message via Yahoo to big_blue_chevy2006
well at school we have a 99 we have replaced the pump on about 4 times and the cheapestpump its 300 bucks, well we always dropped the tank n everytime we put it back up one of the line fittin things on it breaks and we have to buy another. now i know we r abuncha 17 and 18 year olds learning but we have 2 very smartteachers and they are there to watch to. so id to suggest taking off the bed or at least getting a couple jack stands some 2 by 4s and about 4 other guys and slide the bed back a couple feet or so, we did that at school n guess wut teh fuel pump didnt break this time, and haha the 99 chevy only has a 4.3 but itll do an awesome burn out!!! that is with the bed off
Old 04-28-2005, 09:47 AM
Why did you replace the pump 4 times? was it bad? Or just for learning purposes?
The 97 pickup has the pump available separately less than $100, but the 97 Tahoe and the newer pickups have a unitized pump/float assembly for $300+.
Bob B
(Sherman69)
Old 04-28-2005, 03:06 PM
well we do it onceon each truck everyyear but it kept getting broken so we couldnt start the truck butya for learning purposes
Old 05-12-2005, 06:31 PM
diehlrg diehlrg is offline
I cut a access hole int he bed of my truck to do the fuel pump. I had the tank in and out 3 times by myself (36 gal tank 1/2 full). Every time it was out it worked. put it back up and no go. I got the sawzall out after the 3rd time. now should i need to do it again i just unscrew 4 swheet metal screws and there she is!
Old 05-13-2005, 12:02 AM
bad68chev bad68chev is offline
If you keep your fuel tank above 1/4 tank, It won't get hot and will last alot longer. Running the tank completely empty shortens the life as there is no fuel to keep it cool. Just my 2 cents.
