Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 04-20-2005, 06:25 AM
GOTTIFEID GOTTIFEID is offline
97 4.3 Wont start, too much gas? Help
Ok here goes it started out loosing power like a plugged fuel filter,I changed it... nothing.. still power loss.
Now it wont start without starting fluid. I was just giong to change the Fuel pump again ya know?(seems like it might not be pump Though)
but it has a throttle problem I cant give it hardly any throttle or it completely cuts off ( no popping) just like it is getting too much gas and not enough air.
1) would all bad 02 sensors cause this? I didnt think so Thats why I have been running around with 3 bad ones, i think thares 3.
My jimmy has 241,000 miles on it and I dont feel like spending $150 on 02 sensors and have it run the same. I just want to see how many miles I can get out of the 4.3 before it blows up, cause it still runs very good.
2)Could it be the coolant temp sensor? or stuck EGR valve?
Of course I sent someone to buy a pressure tester and it is not the right one so I have to buy another one before I test the fuel pressure, sorry.
Would it run with boaderline gas pressure just not start? no?
The only codes I get are for the 02 sensors
Please Help me out I may have left out something, thanks a bunch
Old 04-20-2005, 10:14 AM
jsgold jsgold is offline
There was a post the other day where a fella had a EGR valve stuck open and truck would "flood". Try unhooking the EGR to see...
I used to be indecisive, now I am not so sure.
Old 04-20-2005, 01:02 PM
JimmySLS's Avatar
JimmySLS JimmySLS is offline
Re: 97 4.3 Wont start, too much gas? Help
Maybe a plugged converter ..You may want to check that too....
Old 04-20-2005, 05:26 PM
I am checking the EGR and fuel pressure today
thank You very much.
Any other ideas?
it does rev up if i hold the trottle open just a little seems like its not the CAT
Old 04-21-2005, 12:44 AM
I AM changing the fuel pump!
Old 04-23-2005, 01:47 AM
Thanks, it was the fuel pump
jap fuel pumps keep working just not good enough
I have been having good luck getting parts warrantied at AZone lately
