Go Back   Automotive Forums Car Chat > Audi > A3 | S3 > '96 - '03
Old 04-20-2005, 05:44 AM
MITSU-EVO MITSU-EVO is offline
Send a message via AIM to MITSU-EVO
What the hell is INSP?
I have got a 99 A3 1.8.
The car constantly keeps saying "service INSP". I assume it means "inspection". Can you give me some info on what it really is?
http://www.basehead.org/files/shots/...tach_5000s.jpg
I DIG EXOTICS!!!
Old 08-13-2005, 04:09 PM
ctesla's Avatar
ctesla ctesla is offline
does your A3 have VDO? most do, but some have the (Nippon/Seiki)?
this should work...
if not, you will have to find someone with either a MODIS or VAG-COM scanner. I know this covers most of the B4 platforms though;
(also, if you have not serviced your Audi, do so)
then:
Switch ignition off.
- Press trip recorder reset button below speedometer on the instrument cluster at same time switch ignition on.
The trip recorder display (odometer) will read "service OIL".
- Release button.
- Pull the clock adjuster button (below tachometer) on the instrument cluster and hold for approximately two seconds. This resets "service OIL" display.
Note: Depending on the make of the instrument cluster, the display on the trip recorder will either continue to read "service OIL" (Nippon Seiki) or change to "- - -" (VDO).
- Press trip recorder reset button again to advance to next type of service.
- Release button.
The trip recorder display will read "service INSP".
- Pull the clock adjuster button on instrument cluster and hold for again approximately two seconds. This resets "service INSP" display.
(see previous note depending on display)
- Switch ignition off.
-TaDa.
hope this works for you,
chris
nrt racing
