Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-20-2005, 01:31 AM
Medabots Medabots is offline
Question N/A or Turbo ?
HI everyone, its me again. This time I'm just trying to figure out what set up should I run.
I already have a 95 LS engine in my 94 civic hatch, I also have a 8lbs flywheel and stage 1 clutch kit. I'm thinking about the all motor set up, running high compression pistons, changing the retainers and valves, cams and working the buttom end in a decent way (by decent I ment relaible). Turbo is nice and expensive (just like the NA set up) but I think turbo requiere more care than High compression. Turbo is also more noticiable, everybody knows when you have turbo (Idont like that Idea to much).
so, what do you think will be better to go wiht (I dont wanna be in the 9's but I want something that I can be confident with).
Here, Money is the Problem......
Old 04-20-2005, 02:23 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: N/A or Turbo ?
depends on how fast you want to go. all motor ls isnt that good, lsvtec on the other hand is good. the ls motor shouldnt be revved high so your limited to the stock rev limiter or alittle over.
Team Lonely Drivers
Old 04-20-2005, 10:21 PM
Re: N/A or Turbo ?
I know the LS is not that good, but it is one of the motors that can take a lot of miles (very resistent). I want to reach at least the 200 or 250 HP all motor, and I dont think is that hard.
Remember, I just want something that I could say "I spent some money on it and it was whell worth"..... so please give an opinion and/or a tip on how to reach my goal.
Still trying to get a GOOD price in a LS transmission...
Old 04-20-2005, 11:30 PM
turboEKhatch turboEKhatch is offline
Re: N/A or Turbo ?
I had a built B20/VTEC with cams, pistons, rods, ported head, the whole 9 yards. It made just under 230 WHP naturally aspirated and was pretty quick. I really liked it. Till my friend with a stock LS motor and a T3/TO4E 50-trim beat the living shit out of my car on the street for about 1/2 what I had invested. I have gone turbo and never looked back. My new motor is an exospeed 84mm LS/VTEC in a GSR block with an SC61, hoping for 400+ WHP and still daily driveable!
Old 04-21-2005, 01:15 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: N/A or Turbo ?
search
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 04-21-2005, 01:21 AM
Re: Re: N/A or Turbo ?
Thats impresive! one question, did you friend worked the block and the head? or he just drop a turbo on the LS?.... I know that you can just drop a turbo on the stock LS and run low Psi, but what about if I wnat to run more psi? what parts of the motor should I work on to resist that much power?
Forged pistons, rods and all that is too expensive. there is not reliable way to have a fast and intimidating car? if you know any let me know.
Old 04-21-2005, 01:18 PM
Re: Re: Re: N/A or Turbo ?
Completely stock LS motor. Stock block, crank, rods, pistons, head, headstuds, headgasket, valves, cams, intake manifold, rod bolts, oil pump, clutch, everything. I ran 14 pounds of boost or around 310 WHP daily on my stock LS block with new head studs and rod bolts, tuned on Hondata. Driven daily, and I was quite hard on it. Ringlands eventually went at around 20K miles but I wasn't complaining. The weakest link in the LS motor from the factory is the rod bolts, they're very prone to streching and then they let go and destroy your motor. Doing it again I would have kept it to around 275 WHP for my daily driver, more was just pushing it.
Old 04-21-2005, 03:00 PM
Skyline_BNR34's Avatar
Skyline_BNR34 Skyline_BNR34 is offline
Registered User
Re: N/A or Turbo ?
It's all up to you. N/A are good but not all the time, Turbo will have more HP but there is problems with both and stuff. So do what you want with your car. If I was you Get the turbo...
