Old 04-19-2005, 11:07 PM
awdpower awdpower is offline
Send a message via ICQ to awdpower Send a message via AIM to awdpower Send a message via Yahoo to awdpower
does anybody know where this sensor goes
the computer reads theis from my check engine light- 02 sensor heater circuit malfunction (bank 1 sensor 2) does anybody know where that sensor goes. also Clsd loop Fuel Ctrl Insufficient Coolant Temp. If anybody could help me because my car is slow right know and I need to fix this thanks????
Old 04-19-2005, 11:44 PM
coolguycooz coolguycooz is offline
the heater 02 sensor is one of the wires that goes to the 02 sensor. the 02 sensor has 4 wires comming from it check out the heater wire see if its cut or something inspect it all the way from the 02 sensor to the connector if its cut there just hook it up if its not there then keep checking it all the way after the connector.
96 RS 5 spd.(Daily Driver and ex Ricer "I am ashamed of it")
98 GSX 5 spd. (Currently stock, spending all my mod money on body work.)
Old 04-20-2005, 10:15 AM
Re: does anybody know where this sensor goes
but where is that sensor so i can check it out. and how about the Clsd loop fuel Ctrl Insufficient Coolant temp
Old 04-20-2005, 01:21 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Also sounds like you coolant temp sensor is shot. Do you have access to a logger? Keep in mind that just because your coolant gauge is working doesn't mean that everything is OK. There are 2 coolant temp sensors. One "feeds" the gauge and one feeds the ECU. The one feeding the ECU may be shot. Normally when they die, the ECU sees a coolant temp of -40 degrees (I think).
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-20-2005, 02:38 PM
Re: Re: does anybody know where this sensor goes
what is a logger. Is i t the little orange computer to check what is wrong because of the check engine light
Old 04-20-2005, 02:52 PM
kjewer1 kjewer1 is offline
AF - Advisor
All of the above is balls on.
Sensor 2 bank one is the rear O2 sensor, after the cat. They fail eventually, I would just replace it.
I've had no coolant temp sensor (broke the wires off) and didnt get that DTC, but that sure is what it sounds like. The ECU wont go into closed loop control of AFR until it thinks the motor is warmed up. If it never sees the warmed up temps, it may time out eventually. I would replace that sensor and/or check the wiring. Its on the thermostat housing/water neck, the one with 2 wires. I believe it is the one right next to the upper radiator hose, but my car is so far from stock its hard to be sure thats where it is on your car.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-20-2005, 03:30 PM
Re: Re: Re: does anybody know where this sensor goes
But there are 2 things that the computer was reading and that are wrong with my car unless the 02 sensor is causing trouble with the coolant temp. #1 is the 02 sensor malfunction and #2 is the loop fuel coolant temp. what you were saying, did u meant all that was one thing.
Old 04-20-2005, 03:36 PM
Re: Re: Re: Re: does anybody know where this sensor goes
so where is he 02 sensor located at
Old 04-20-2005, 03:39 PM
AF - Advisor
...coolant temp sensor.... Its on the thermostat housing/water neck, the one with 2 wires. I believe it is the one right next to the upper radiator hose...
2 seperate sensors. One on the exhaust after the car, and the other by the upper radiator hose.
Kevin Jewer
Old 04-20-2005, 03:49 PM
ok so the 02 sensor is by the cat-back right? and the -Clsd loop fuel Ctrl Insufficient Coolant temp- is also a sensor that is malfunctioning???
Old 04-20-2005, 03:50 PM
AF - Advisor
Yes. Both unrelated to each other.
Kevin Jewer
Old 04-20-2005, 03:54 PM
ok im getting things cleared up now. so the coolant temp sensor is by the upper radiator right.
Old 04-20-2005, 04:47 PM
how come you say its a sensor for the coolant temp. if the computer didnt say anything a sensor
Old 04-21-2005, 10:07 PM
AF - Advisor
If your coolant is up to temp, and the ECU thinks its not, it would have to be the sensor or the wiring. I'm almost positive thats what that fuel trim code is telling you, but I reserve the right to be wrong. If you want more certainty, take it to a dealer.
Kevin Jewer
Old 04-22-2005, 11:17 AM
that would be all expensive wont it?
