| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
93 eldorado keeps stalling out whlie driving
Hello all! I have a 93 eldorado with the northstar engine with 102000 miles. When i drive down the road going about 40 mph the car will die. It will restart when i put it in N and the car is still rolling after a few attemps. It will do this on average 3 or 4 times within a mile of driving. It also dies sometimes when i am slowing down for a stop, when this happens, the car will most of the time not start up. The first time this happened I had it towed to my house, paid the tow truck guy and just out of curiousity tryied to start it, and it started right up! Lately, when it dies and won't start back up, i leave it sit for about 6 or 7 hours, get a ride back to where it is at and it starts right up. This has been goin on for about 2 months now, and yesterday it died coming up on a stop, I went back to start it today and it didn't start. I don't know what to do or have never heard of such a problem. If any one has any suggestions or commets please email me at [email protected] Thank you for your time! Any help would be greatly appreciated!
#2 | |
Re: 93 eldorado keeps stalling out whlie driving
Have you tried to pull up any ECM codes?
#3 | |
Hi, I have a similar problem but not as bad. I also have a 93 eldorado that stalls. I don't have a northstar engine though and mine always starts back up (luckily). My stalling use to occur much more when I wasn't driving my car a lot but it seems that now i drive it everyday its helped A LOT. I've been driving it everyday for about 6 weeks and it has only stalled twice now i think. I dont know if you have this too but my engine sometimes seems to just about shut down on the highway, it doesn't stall out but the engine light comes on for a minute or 2 it won't accelerate like it should. But if you have found out more about your problem or have gotten it fixed could you please pass on the info. Thanks!
#4 | |
![]() Join Date: Feb 2005
First thing you should do is check for codes in diagnostic mode.
To enter diagnostic mode: 1. Turn ignition "ON." 2. Depress the "OFF" and "WARMER" buttons on the Climate Control Center (CCC) simultaneously and hold until the segment check appears on the Instrument Panel Cluster (IPC). To get out of the diagnostic mode anytime during the test, depress the "AUTO" or "DEFOG" button, or turn the ignition switch "OFF." Trouble codes are not erased if this is done prior to selecting "CODES CLEARED." Here is where you can find out what the codes mean: http://myweb.accessus.net/~090/dtcobd1.html |
#5 | |
I was just wondering if you found out what the problem with your caddy was. I have the same problem with mine and have never been able to solve it. No error codes show up, have changed the map sensor, (3 times) plug wires, plugs, and all wireing seems to be ok. This seems to be a problem with all caddys and no one has a solution. Please respond to [email protected] if anyone has an answer for this.
#6 | ||
#7 | |
Found problem with stalling and trashing of map sensors. The fuel rail had a busted plastic line on it allowing raw gas to enter the manifold, which evidently was affecting the map sensors (the raw gas). Also changed the thermostat as the problem seemed to compound itself the hotter the car gets. Sure is a sorry rig up on the fuel injectors. 43,000.00 for a plastic toy!!!
