Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-19-2005, 09:25 PM
firedemonlord89 firedemonlord89 is offline
Send a message via AIM to firedemonlord89
Exclamation rear light problems
i have a problem with my rear lights not coming on when puttin it in reverse. i went to da mechanic and he said the rear switch if dead...can someone tell me where da switch is so i can fix it
thanx
Old 04-21-2005, 05:21 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: rear light problems
i not sure were DA switch is. maybe ask DA mechanic where DA switch is. dat way you can fix DA switch, ya? so wen puttin da gear in reverse da lites will come on, jah?
Not too sure man, just write/talk normal from now on. If you have a haynes or chilton manual take a look in there.
"You can have everything in life you want if you will just help enough other people get what they want."
