Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 04-19-2005, 08:23 PM
RedCavalierRacer's Avatar
RedCavalierRacer RedCavalierRacer is offline
Send a message via AIM to RedCavalierRacer
Bolt Pattern
What bolt pattern do cavalier have?
5 x 100?
5 x 114?
Old 04-19-2005, 09:09 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Bolt Pattern
5x100 ... hub size is 57.1mm for when you need the # for hubcentric rings.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 04-19-2005, 11:27 PM
Re: Re: Bolt Pattern
What would I need hubcentric rings for?
Anything important?
Old 04-20-2005, 09:50 AM
Lifted GMT-360!
Re: Bolt Pattern
Most wheel companies will send them with the new wheels like Motegi for one. Some vehicles are lug centric which means when you tighen the lugs, the wheel will be centered and you won't get vibrations when driving. J-bodys are hubcentric which means the wheel has to sit on the hub for it to spin true. If you look at your stock wheels when they are on the car without the plastic hub caps, its sits on a circular disc. called the hub. The hub is also your wheel bearing assembly. The hub size is 57.1mm on j-bodies. So say you go out and buy a set of rims that are 10 lug universal and universaly bored. It is going to have an extremly large bore size to accomodate other cars that have different hub sizes. When i bought my wheels i didn't know about these, and just threw the wheels on my car no questions asked. I could only go about 40-50 mph before my whole front end shook. I thought it was just severly unbalaces but it was not. I did a little research and found i needed the rings. I called up the company that made them and asked for the bore size ( first time around some fucking Foreigner gave the wrong Size and i got the wrong rings, so i have 2 sets now and maybe even 3. ) THere should be no play in them when you stick them in your wheels. I have 73mm on my rims right now, but i have a little play so i might get 1mm larger. These rings fill in the gap between the bore of the rim and your Hub size. So if you get wheel vibs, these are what fix it. Even if its off just slightly, it can cause serious vibs at high speeds.
Old 04-20-2005, 11:13 AM
Oh alright, So if I bought the Motegi MR7's then would they come with these rings?
Old 04-20-2005, 11:28 AM
Lifted GMT-360!
Re: Bolt Pattern
Just, but that isn't a reason for buying those. I think those rims have been played out way too much. Be unique. Shit a set of the rings are only friggen 5-8 bucks. You just need the outter diameter #
Old 04-20-2005, 06:32 PM
I like the Motegi MR7's chrome but I also do like those black ones that I showed you.
There about the same price
Old 04-20-2005, 09:40 PM
Lifted GMT-360!
Re: Bolt Pattern
Try and get a package deal with tires mounted. Gettin wheels mounted to your rim is very pricey i found out... I had to end up paying fuckin 120 bucks to get them mounted and balanced.
Old 04-20-2005, 11:07 PM
01Cavy 01Cavy is offline
Send a message via AIM to 01Cavy
I didn't get rings with mine, and have no vibrations when driving. Went up to 90 on the interstate with no problems. Guess I lucked out and got rims that fit.
2001 Toyota Celica GT
Check out my CarDomain at...
http://www.cardomain.com/ride/2493960
Old 04-21-2005, 11:17 AM
Lifted GMT-360!
Re: Bolt Pattern
some companies make it so some rims are direct fit to your car.
Old 04-21-2005, 12:26 PM
Yeah, My buddy got his rims mounted and balanced for his 20's and he got them for pretty cheap. He got a really really good deal.
Old 04-21-2005, 09:47 PM
Lifted GMT-360!
Re: Bolt Pattern
good deals are hard to come by with aftermarket products.
Old 04-22-2005, 08:17 AM
Yeah I was surprised considering they were oof of ebay, but they were still nice
Old 04-22-2005, 09:02 AM
Lifted GMT-360!
Re: Bolt Pattern
i'd be careful with ebay.. just iffy bout them.
Old 04-22-2005, 05:25 PM
I don't trust anything off of ebay anymore after I started on this site.
Ebay is cool when your buying this that are expensive at the store and they have a brand name, but they are cheaper on ebay.
Otherwise I dont trust any generic stuff off of ebay anymore.
