Old 04-19-2005, 07:11 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Legacy Cap
I know that people will post that caps are useless, thats fine your opion is noted. Check out http://www.etronics.com/product.asp?...rd&svbname=403 is this cap any good? If not what are some other caps that are about the same price $60? I don't need a fancy one just on to work with my system (2000W Performance Teknique Amp, 10" MTX Subs). Thanks in advance
White 07 STI, Bone stock for now
Old 04-19-2005, 08:38 PM
notladstyle@yahoo. notladstyle@yahoo. is offline
Send a message via AIM to notladstyle@yahoo. Send a message via Yahoo to notladstyle@yahoo.
Re: Legacy Cap
Caps should be rated at 16v +/-5% for best efficiency in a car. 20-24v will not do you any good, most of the equipment in a car would not operate at 20v
Neon Lights add 10hp... per color
It seems my sig pic was too big for some ppl to see on their screens - srry about that
Old 04-19-2005, 09:42 PM
Brandish's Avatar
Brandish Brandish is offline
Re: Legacy Cap
Efficiency??? Please elaborate... Most car audio caps will be rated at least 20V anyways.
A cap is a cap... Find an electronics distributor that will sell a 1 farad capacitor to you off the shelf with no fancy logos for less than half the price. Just remember to use a resistor or charging bulb.
Old 04-19-2005, 11:52 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: Legacy Cap
1) Caps are useless
2) Legacy is trash
3) Don't do it
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 04-20-2005, 07:43 AM
Re: Re: Legacy Cap
20v capacitors to not offer as fast transient response(they don't smooth the spikes as well) and the electrical capacity is slightly less than a 16v capacitor would be. eg. Charging a 20v capacitor at 14.5 volts will exceed its lower tolerance rating and will result in a lowered capacitance while a 14.5 volts to a 16v cap will be within tolerance specs.
Most cheaper caps are rated at 20v, 16v are a little more expensive. You will very rarely find a 20v 1 farad capacitor. You will more than likely find 1 farad 350v caps which will do you no good. Legacy makes 2nd tier products anyways.
Old 04-20-2005, 05:28 PM
germanyt germanyt is offline
Re: Legacy Cap
if you really feel you need a cap or maybe you just want one for looks, you pretty much cant go wrong. i dont believe any one company is better at making caps than any other. the only thing that really differs is the voltage, ampherage, and the size. two caps with the same of each of these from different companies are going to work exactly the same.
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
