Old 04-19-2005, 05:47 PM
adblink182 adblink182 is offline
Neons in the Grill?
drove by a parking lot a few days ago and had a bunch of nice gps (had a tear in my eye *sob* lol jk) anyway! one had a blue neon light comming out of the grill, I thought it looked pretty sick
anyone ever done this before? and seen how they did it?
Old 04-19-2005, 07:59 PM
phaelax phaelax is offline
Re: Neons in the Grill?
wouldn't be hard to do, just get a small enough light umm, whatever those long ones are called, having a brain fart at the moment. Just fasten it behind the grills and run the wires up.
Old 04-19-2005, 08:22 PM
notladstyle@yahoo. notladstyle@yahoo. is offline
Send a message via AIM to notladstyle@yahoo. Send a message via Yahoo to notladstyle@yahoo.
You will get so much crap from cops for mounting neons into the grill. Any directly forward facing light will get you a ticket for unecessary disctraction(although I have never seen a fully loaded Z06 get a ticket for this and its distracting from every angle)
Remove the fanwell cover and tap headlight wires for power its pretty straight forward. dont use indoor lights, they wont last a month. use LED or neons designed for exterior use.
Neon Lights add 10hp... per color
It seems my sig pic was too big for some ppl to see on their screens - srry about that
Old 04-19-2005, 08:28 PM
hmm ur write it shouldnt be hard to do. I wouldnt tap into the headlights for a few reasons, you wouldnt be able to turn them off if I cop was comming around you etc, you wouldnt be able to turn them on say in a parking lot without having your headlights on
I want to get a underbody neon kit in the near future and want to be able to sit in a parking lot for example with everything on, so when I do get those, I'm going to have to figure out how to wire them all up to one switch
Old 04-19-2005, 08:33 PM
Re: Re: Neons in the Grill?
well thats the ghetto rid version of how to do it. The proper way is to use a 10a automotive relay and run from the 1.foglights if you are lazy 2.run a wire inside through the firewall to a switch inside - my neon switch is right next to my heated seat control...
BTW, does anyone have a good suggestion of a way to mount my LCD without making it non removable?
Old 04-19-2005, 10:18 PM
ya I would probably run it through the firewall to a switch. How do you exactly use the relay?
Old 04-20-2005, 07:26 AM
http://www.bcae1.com/relays.htm
Good site for the basics. Basicly a relay allows you to take a low current output and use it to 'switch on' a device with a higher current draw. Since you are right next to the battery you could run a wire from the battery to the neons, I used the headlights output because my lights are LED and draw less than 4 amps total and I like them to flash with my keyless entry.
Old 04-20-2005, 11:24 AM
but then u run into the same problem I was talking abotu before right? where you can only have them on when ur headlights are on and then have no way of turning them off without turning off the car
Old 04-20-2005, 12:29 PM
no, the switch is like the master control, but if you leave the switch on, the neons will shut off with the foglights. If you are planning on running in a parking lot, dont use the foglight tap. I am often forgetfull and I leave the neon switch on, so when I shut off the car the foglights turn off and the relay will shut off as well, even if the switch inside is still on. If a cop comes, the switch will trip the relay to shut them off.
