Old 04-19-2005, 05:08 PM
Sen Sen's Avatar
Sen Sen Sen Sen is offline
headliners?
Has anyone replaced/removed/installed the headliner on the 1st gen blazers?
From what I've seen there seems to be about 5 panels that need to be removed...
Is it contact cement they use to hold it up?
Will it rip off with the carpet?
any input would be great!
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Faster and louder than stock, but nonetheless a blazer!
Old 04-19-2005, 07:03 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: headliners?
Poke a TINY hole in placed positions and spray adhesive and reglue the liner up.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-19-2005, 07:58 PM
Sen Sen's Avatar
Re: headliners?
never thought of that...thanks
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Old 04-19-2005, 09:59 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: headliners?
I tried what Lt said for my 91 did not work. A couple of my buddys did them for there old beaters and gave me some general knowledge. You would have to remove the panels in the back sides front sides and the sunvisors. The hold down strap things are pretty hard to get at with a socket. I am going to be doing mine this summer if i find the fabric i want. For now i broke out the old staple gun pushed all the fabric to front no air pockets hid them staples behind the sunvisors since i dont use them anyway. Thought i give my 2 cents.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 04-19-2005, 10:21 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: headliners?
i tryed the hole thing with my old 1500 (i say old beause i dont drive it no more) but it didnt work, wound up being the best way to do it was to take the headliner off, then peel it back to the spot and reglue, when i did the hole thing, it was a big enough area, it looked like a stain... use your perverted imagaination..., to much glue in one spot, and the hard glue spot looked 100 times worse then the sagging
Old 04-19-2005, 10:51 PM
Sen Sen's Avatar
Re: headliners?
I was considering fixing the headliner or putting a custom one up with a nice design.
but once I have the panels off... is there anything else i should worry about or can i just rip the bastard right off.
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Old 04-19-2005, 11:17 PM
Re: headliners?
worrie about your overhead council, if you have one, a dome light, and o shit bars
Old 04-20-2005, 12:20 AM
hunter01 hunter01 is offline
Re: headliners?
3M makes a "General Trim Adhesive" and on the can it says -"Do not use this product to bond headliner fabric that has pulled away from it's foam backing. This product is designed to bond foamed backed headliner to a backer board."- I have seen a link for replacement headliner fabric with the foam backing somewhere in this forum. If I can find it I'll post it again. If you get the fabric and the spray glue maybe you can use the old backer board. Also as a temporary fix I have seen narrow strips of thin plywood or paneling used as ribs to hold the fabric up to keep it from rubbing on your head.(very annoying) Depending on the molding on the sides sometimes you can cut them exactly to length and just wedge them in without any fasteners.
Old 04-20-2005, 02:49 PM
Sen Sen's Avatar
Re: headliners?
I have read that "super 77" adhisive spray works really well. and regular chipboard could be used for a backing?
or foam?
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Old 04-20-2005, 09:21 PM
Re: headliners?
i would not know about super 77. i am looking into getting abs plastic for mine or a replacement foam board
