Old 04-19-2005, 05:01 PM
GTPWarrior's Avatar
GTPWarrior GTPWarrior is offline
Question does anyone know the answer?
Okay I will try to explai the best I can. Its an 84 diesel blazer. On the fuel injector filter/Pump(?) the big squre one on the firewall on the passenger side with the air release scew on top. Has two line on the botttom (one front left and one back right When faceing it from the front) one in back has a hose going back to tank and the other is missing the hose (?) is there supposed to be a hose there and if so where in the hell does it go. I am assuming that there is supposed to be a hose because when I tried to re prime I developed a puddle under the truck with fuel.
Please someone say they have the answers.
[b]1998 Pontiac Grand Prix GTP
"A man walks into a bar and says.....................*ouch*"[/b]
Old 04-19-2005, 09:51 PM
GTPWarrior's Avatar
If someone could tell me how to post a picture i can send a pic of what I am talking about.
Old 04-19-2005, 10:35 PM
Turbocpe Turbocpe is offline
To post an image:
1) Visit your Photo Gallery:
http://files.automotiveforums.com/ga...ploadphoto.php
2) Login when prompted
3) Click on the Browse button next to the Photo Upload field
4) Find the file on your hard drive in the window that pops up
5) Once you've located the file in Step 4 and then clicked on the Open/OK button, then click on the Upload/Submit button
6) Now click on the My Gallery link
7) Find the image and click on the thumbnail
8) Below the picture, you'll see:
"Share this photograph on the message board:"
Highlight the entire command found on the line below and then Right-click and select Copy to copy the data to your Windows clipboard
9) Come back to the forums and simply paste the command in the reply.
Old 04-19-2005, 10:52 PM
GTPWarrior's Avatar
Re: does anyone know the answer?
This is the under side pic. see only one hose but two Little pipes
Old 04-20-2005, 05:02 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Never had a diesel blazer (had a few diesel VW Rabbits and a Diesel 505 Peugeot (great car), but if I remember correctly that is just the drain for when bleeding the air out... It's a sealed system so there isn't a return fuel line like on self purging gas motors. More than likely a hose just goes on there to drain it away from the engine. Again, I'm not 100% sure on this as it's been a long time since I've had to bleed out a diesel motor (much less really work on one).
Old 04-20-2005, 09:45 AM
GTPWarrior's Avatar
There is a hose on the side just below the bleeder screw, twards the top. Not saying your wrong in any way. But just seems wierd to purge air from underneath. But knowing there is no return line helps. So where does the unused fuel go?
When I punch the gas going up hills I spray fuel. Any ideas why?
