Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 04-19-2005, 04:10 PM
cgm707 cgm707 is offline
Question necessary fixes?
I have a 1990 Cadillac DeVille with about 86,000 miles on it. I bought it from someone who seldom drove the car obviously. However I have had to put a fair amount of money into the car. The mechanic told me that some things that have to be fixed include:
- Transmission mount
- Exhaust manifold
- Struts & shocks
The car also leaks quite a bit of oil and I am told that to fix this would be very expensive.
Anyway, I want to sell the car and am wondering if these things should be fixed first, and what a fair price would be?
Thanks for any help.
Chris Milligan
Old 04-29-2005, 05:39 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
Hmmm a fair price? How about the price of a gallon of gas and one match. Burn the pos to the ground. The re-seal for the oil leak will run well over $1500 and the front struts about the same.
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 06-06-2005, 09:24 PM
MarkC MarkC is offline
Re: necessary fixes?
my 89 leaked oil and all it took was to snug up a few loose oil pan bolts on the drivers side to fix it.
Old 06-09-2005, 01:03 PM
ACDC686 ACDC686 is offline
Well, if the oil just leaks around the pan, make sure the bolts are to the correct torque specs and if they are make sure there are no holes in it. If its neither of those, drain the oil, and drop the pan of and replace the gasket. My trans oil pan leaked and alls it took was a simple gasket replacement and now its fine. Easy home project, just a little messy as their is no drain plug in a transmission oil pan.
