Old 04-19-2005, 03:42 PM
allwar187365 allwar187365 is offline
Unhappy burned out ignition fuse
ok i have a 95 metro ignition fuse keeps blowing out when i turn the key i searched the forum and i did the pulling of all fuses and left the ignition one on and it blew alone i checked the wires going to the fire wall theres nothing melted in the wires i have a multimeter is there any way i can use it to do anything related to my problem im not very good with elecrical stuff im just looking around the car trying to figure out something please help
Old 04-20-2005, 11:02 AM
spy1309 spy1309 is offline
The short might be in the ignition switch or you have a huge curent draw maby from the starter .
Old 09-05-2005, 09:41 PM
escapingoth escapingoth is offline
Re: burned out ignition fuse
I am having the same problems.
I found that when I disconect the ground wire from the ignition coil the fuse no longer blows and I can start the car. I checked it tonight and found that there is .12volts from the unhooked ground wire to ground. It is really weird because the ignition coil is bolted directly to the firewall.
Did you manage to get yours sorted out.
Thanks
Old 09-06-2005, 01:50 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
on some of the metro's there is a noise supresion capacitor running from the coil to ground, if it shorts that can cause fuse to blow
Old 09-06-2005, 09:08 AM
Re: Re: burned out ignition fuse
Thank you for responding. Do you know if the capacitor is built into the coil.
Old 09-06-2005, 07:03 PM
Crvett69's Avatar
no, its bolted to one of the coil hold down bolts i think, look for a 1/2" round metal can looking thing with 1 wire going to it
Old 09-06-2005, 08:57 PM
Thank you for your help. I did finally manage (I think, hope and pray) that I found the problem. It was a burnt connector in the fuse box. If I can I'll post a pic tomorrow.
Old 08-06-2007, 04:45 PM
carpenter_jai's Avatar
carpenter_jai carpenter_jai is offline
AF Stunt Driver
I wonder which connector was the culprit...
Jai
96 3 cylinder Geo Metro (currently being rebuilt)
