Old 04-19-2005, 04:33 PM
bear_1961 bear_1961 is offline
New Power Steering Pump groans and foams
Just installed new power steering pump. Bled it out per instructions. It groans and is full of foam. Acts like it still has air trapped in lines. No sign of leaks. Any ideas?
Old 04-19-2005, 08:00 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: New Power Steering Pump groans and foams
Unplug the wiring to the coil. Jack up front end, crank engine over while you turn steering lock to lock for about 30 seconds. Do this 3 or 4 times. Turn steering all the way to right and turn ignition to lock. All the bubbles should come out.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-19-2005, 10:21 PM
wiswind wiswind is offline
Just a note to add.... You may need to stop and wait for the bubbles to raise out of the fluid....as in wait until the foam works out of the fluid....and then continue as instructed.... Otherwise....you will be recirculating the air back into the steering rack.
Old 04-19-2005, 10:44 PM
CoachKarl CoachKarl is offline
I've installed two on a 95 3.8. Groaning PS pump is typical, much louder than normal for the first few trips. I work in a new one with a few complete turns of the wheels on the lift, followed by about 10 figure 8 turns on my dead end street. (er, cul du sac) As log as it ain't screeching, it should sound better in a week.
Old 04-20-2005, 10:47 AM
All of the input is most appreciated! I will try your suggestions. This thing is driving me nuts. One question though, Autozone had me use Dexron III for power steering fluid, is this correct?
