Old 04-19-2005, 03:22 PM
PawNtheSandman PawNtheSandman is offline
Need a Part # for Vacuum Switch
I need the part number or an image or link to an online retailer that sells the vaccum switch for my 98 4WD.
The people at Napa quoted me $36 but I thought it was around $50 so I want to make sure they are quoting me the correct one.
Old 04-20-2005, 05:17 AM
ricksza's Avatar
ricksza ricksza is offline
Re: Need a Part # for Vacuum Switch
The switch on top of the transfer case?
http://www.napaonline.com/cgi-bin/nc...grpid=78325205
Old 04-20-2005, 12:54 PM
I don't think that is it. I need the piece that the 2 vaccum hoses go into. That is the piece that usually goes bad if your 4wd doesn't engage right?
Old 04-20-2005, 01:33 PM
Turbocpe Turbocpe is offline
That is the unit that has the two vacuum hose ports on it.
Old 04-20-2005, 02:05 PM
My eyesight must be shot because I can't make out a second hose port.
Old 04-21-2005, 07:09 PM
ricksza's Avatar
This switch has three ports. It screws into the top of the transfer case. Is that the switch that you need?
Old 04-21-2005, 07:32 PM
I apologize for my error. I replaced this "switch" just not too long ago due to the ball sticking, and I apparently can't recall the proper number of ports it had. I had thought it had 2 ports and 1 small stud to prevent the vacuum harness "plug" from being put on in a different spot onto the switch.
Old 04-22-2005, 08:59 AM
Re: Re: Need a Part # for Vacuum Switch
Yes I need that one.
Old 08-12-2005, 09:28 PM
djd99's Avatar
djd99 djd99 is offline
Vacuum spec Please
I have a 2000 blazer 4x4 with the 4.3.... I have recently notice a power loss and poor gas milage. I have replaced all the vacuum lines that the eye can see and found 1 that had a huge hole in it. I connected my vacuum gauge and it reads 15 at idle and 20 when it's accelerated. Is this the correct spec or should I check for more leaks?. Thanks Don
2000 S10Blazer LT 4 Door 4x4
Billet Grille insert
Winter 30X9.5QR15 BFG's All-Terrain T/A KO's
