Old 04-19-2005, 02:38 PM
talontsi26 talontsi26 is offline
fuel pumps/balance shaft
what is the difference between a walbro 255 high pressure and low pressure fuel pump....also what are the pros and cons of removing the balance shaft???
Old 04-19-2005, 07:00 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: fuel pumps/balance shaft
As for the pumps... A high pressure pump needs a fuel pressure regulator and the low pressure does not... that's what I was told by eclipserst anyways.....
As for the balance shaft removal.... it is just one less thing that can go ka-put in your engine!!!! LMAO
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 04-19-2005, 07:06 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Yea, the balance shafts have been known to go nuts and get entangled in the timing belt, therefore causing a SHITLOAD of problems. Plus, it's one less place for a common oil leak to occur. The downside to removing the shafts is that the engine will vibrate a little more at idle.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 04-21-2005, 02:34 AM
does the removal of the balance shaft affect smog in anyway??
Old 04-21-2005, 10:01 PM
kjewer1 kjewer1 is offline
AF - Advisor
Nope.
Both versions of the 255 will require the regulator. There actually isnt a lot of difference in flow between the two at low pressure (~35 psi). They really seperate at around 30 psi boost (73 psi). The HP version has a higher pressure spring in the relief valve, so it doesnt open as early.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
