Old 04-19-2005, 02:10 PM
Tech_n's Avatar
Tech_n Tech_n is offline
No dipstick
Since a month ago, I broke a piece of the dipstick where the stick is inserted and never could put the dipstick back inside where it belongs. I wanted to know is there a way I can take the dipstick line apart. Also, since their isn't any dipstick inside is harming the engine.
I change my oil ever 2 months
Old 04-19-2005, 02:15 PM
Tech_n's Avatar
Re: No dipstick
I have a 97" Pontiac Grand Prix, 3.8 Engine Non Supercharge with 152,000 miles.
Old 04-19-2005, 08:29 PM
notladstyle@yahoo. notladstyle@yahoo. is offline
Send a message via AIM to notladstyle@yahoo. Send a message via Yahoo to notladstyle@yahoo.
Re: Re: No dipstick
I did the same thing, needle nose plyers were my first attempt. then I went for loonger needle nose plyers i bought at autozone they workd finally.. my car had no dipstick for about a month, no real change in performance or mileage.
Neon Lights add 10hp... per color
It seems my sig pic was too big for some ppl to see on their screens - srry about that
Old 04-20-2005, 06:29 AM
Tech_n's Avatar
Re: No dipstick
cool, see mine fell inside where is now I can not grip it so I am just out of luck. Is there any other way I can remove the dipstick pole?
Old 04-20-2005, 07:29 AM
Re: Re: No dipstick
I'm almost positive you could drag it down through the oil reservoir if you were to drop the oil pan and dismantle the dipstick hardware.
Old 04-20-2005, 01:39 PM
Tech_n's Avatar
Re: No dipstick
Isn't that going to be very hard because you have to drop the oil pan and it is located right beside the frame of the car.
Old 04-20-2005, 02:14 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Re: No dipstick
Did the dipstick drop down inside the tube?You should beable to just pull out the dipstick tube then remove it.
~Larry~
ClubGP Member 6530
Since 2001
Old 04-20-2005, 06:23 PM
Re: Re: No dipstick
yes, i could not dream of dropping my oil pan for the horrible labor it would take, and i dont like getting dirty... I dont think its right net to the frame, but you do need to get some of those ramps to raise your car high enough.
if you try to pull it straight down you will prolly get it jammed on the little metal thing that pushes the oil against it, so take it off first.
