| Off-Topic Talk about anything other than cars. |
i just got my pocketlogger today i have a cell light on, it told me 02 sensor heater circuit(bank 1 sensor1). is this the front or rear? because i just replaced the front one, and i dont have a cat anymore, would it be the rear?
thanks |
it could be get under the car and check the wire make sure its not cut or something.
96 RS 5 spd.(Daily Driver and ex Ricer "I am ashamed of it") 98 GSX 5 spd. (Currently stock, spending all my mod money on body work.) |
Re: cel light?
ok. i just found out that it is the front o2, but it is brand new.. would this make the car idle like crap. maybe it only does it till it warmed up i will check tonight.
-1995 Eagle Talon TSI AWD -5 speed -evo 3 GT -SAFC 2 -NGK Plugs -walbro 255 fuel pump -550cc injectors -pocketlogger -2.5 full exhaust (no cat) -30 psi bov |
Re: cel light?
That DTC is letting you know that the catalyst heater on the O2 sensor is not functioning. The heater is used to bring the O2 sensor up to normal operating temperature. Look at your logger and see what the O2 sensor voltage is doing. On a pocketlogger it will be O2 sensor bank 1. Take a look at the voltage at idle and at WOT (don't wreck
). It should be cycling at idle and should peg around 0.90 - 0.98V at WOT. Under deceleration it should drop to 0.00V. Did you buy an OEM O2 sensor or was it aftermarket. If it was aftermarket you may have gotten a sensor without a heater. The heated sensors have 4 wires.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Re: cel light?
yea it has 4 wires, the second o2 i covered in foil, something i read on the vfaq. i have a a/f gauge it reads .96-.98 at wot.
