Old 04-19-2005, 11:52 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Easiest way to make a manual boost controller?
Ok, Im cheap. Especially with what Ive heard about making a HompDept boost controller. How do you make them? Also, are there any disadvantages to it, like boost spike or it breaking really easy? Thanks
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 04-19-2005, 08:26 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Easiest way to make a manual boost controller?
For the price of parts at home depot or the like you can buy a MBC off of ebay for about the same price.....
I would have to say the one important thing is making sure the spring inside is the right size/spring tension.... if it is to loose then you won't be able to get the right pressure you need for higher boost abilities... opposite if the spring is to strong....
I'm not sure of what the 3-way brass piece is called but you will need two hose nipples and a bolt for the third hole which threads into the 3-way to adjust the spring tension against the ball bearing... the ball bearing also needs to be the right size....
Off hand I do not know the size of everything... sorry
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 04-19-2005, 09:52 PM
RSLaser RSLaser is offline
Its amazing when you use the SEARCH
http://www.geocities.com/chmwatson/FAQs/mbc.html
1991 Plymouth Laser RS
Only sat for a few years....
Old 04-19-2005, 10:07 PM
search?... wow we have one of those options?....
sarcasm... gotta love it...
