Old 04-19-2005, 10:41 AM
jimmydager jimmydager is offline
Oil leak
Hey,
I purchased my truck recently and the previous owner at some point must have screwed up the threads on the oil pan plug. I took it to get the oil changed and they told me that there was an expandable plug in it. It has a slow leak all the time coming from the plug. They told me that I needed to replace the pan because the threads were so screwed up that it couldn't be rethreaded. Do you guys know of any trick to fix or slow the leak, short of spending a ton to replace the pan?
Thanks,
Jimmy Dager
Old 04-19-2005, 11:41 AM
biglogonafrogbig biglogonafrogbig is offline
I don't know much but depending on how you want to do it you could possibly seal up the plug and then tap a new one next to it, or you could even just drill a hole and put a small screw in it . I doubt either one of these ideas are any good but it might help if your just wanting a rig up
Old 04-19-2005, 07:02 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Re: Oil leak
You could possibly get some thread sealant like they use on steel gas pipes and smear on the bolt threads. Either that or put teflon tape sealant around the bolt and that should help slow the leak.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 04-19-2005, 08:35 PM
sitdusa sitdusa is offline
Re: Oil leak
I would put a rubber o-ring on it to see if that would stop, or slow down the leak
Old 04-19-2005, 09:11 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Oil leak
do you know anyone with a mig welder? weld in a new bung with the right threads.
