Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 04-05-2002, 08:19 AM
Fast_4sho Fast_4sho is offline
rb20det or sr20det
which one should i get. from what i hear a 6 can spool a turbo quicker than a 4. i also figure the extra torque would be good. what other disadvantadges and advantadges are there
Where u at?
where u at?
in my rearview thats where u at!!!
Old 04-05-2002, 11:00 AM
Gonthrax's Avatar
Gonthrax Gonthrax is offline
Skyline Guy
Send a message via AIM to Gonthrax
Well, sense you will have more exhaust flow I suppose it would spool it quicker. In my opinion the RB is the engine with the most potential out of the two. RB20DETs are very strong engines and they respond very well to mods. They are a bit more expensive but if you have the money to spend on um they are worth it.
Member of AF's Slide Squad (Member #04)
Originally posted by taranaki
Postcounts - Phoey....it's not how often you speak,it's whether you actually say anything that matters.
Neishlin Motors
Soon to be my best friend
Old 04-07-2002, 11:46 AM
ImportNut1212 ImportNut1212 is offline
Send a message via AIM to ImportNut1212
what car is the rb20det out of? and where is a website to order one?
original tofu crew member #06
my car=95 240sx se w/ s14 sr20det
lUcAs-----
Old 04-07-2002, 11:07 PM
CA31_JR CA31_JR is offline
RB20DET engines come out of A31 Nissa Cefiro and R32 GTS-T Nissan Skylines. The Skyline engine and computer is the better combo to get as the engine has higher cut-out points as standard but if your going to tune it or go aftermarket then I no difference...
In Oz RB20DET engines are significantly cheaper than SR20DET engines. The SR20DET seems to be overly popular out here....
I can say that the RB20DEt is nice. With only limited bolt-on mods you can make 250KW at the wheels.....
And they sound nicer than a 4.
Cefiro? How do you pronounce that again?
Old 04-07-2002, 11:39 PM
Jay! Jay! is offline
Horizontally Opposed
Wasn't the RB20DET in the Z31, too? Like the 200ZR? How does that one compare?
Hierarchy of Subaru:
(Click to see mine!)
Old 04-08-2002, 10:01 PM
rockerdude rockerdude is offline
i thought you can't swap in a RB20 into a 240sx. wouldn't it create understeer since the RB20 engine is bigger than the sr20? or is the RB engine weigh the same like the sr20?
Old 04-09-2002, 11:50 AM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
you can order the RB20DET from www.unstable-hybrids.com
they swapped one into an S13 240 SX.
If your going to be swapping either of these into the 240 SX then I think the SR might be a less complicated swap, but the RB would be cooler :coolguy:
Old 04-09-2002, 03:13 PM
i heard that all the RB series engine use fuel that doesn't even exist out here in america. i know the octane is above 91. so i'm guessing getting a skyline engine will also cause you to pay a way more extra for the fuel just so the engine won't cause denotation
