Old 04-18-2005, 09:58 PM
EXTREME02 EXTREME02 is offline
Angry Air Conditioner
My truck runs fine until I turn on the AC then it start chuging and losin horsepower. I did a full tune up and recharged the air. any one have any ideas what might cause this.
Old 04-18-2005, 10:38 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Air Conditioner
reset your timeing, unlikely, but ive had it happen once b4
Old 04-19-2005, 05:53 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Air Conditioner
He has a 2000, can't time those...Loss of power is normal when AC is on, if it nearly stops the truck, have your compressor bearing looked at.
Old 04-19-2005, 08:58 AM
Re: Air Conditioner
^wow, thats a bitch
Old 04-19-2005, 05:12 PM
Air Conditioner
I had the compressor bearing looked and it was fine but the thing is a also have this problem when i turn on the heator and not just the AC .
Old 04-19-2005, 05:15 PM
Re: Air Conditioner
sorry havin trouble typin today.
Old 04-19-2005, 10:45 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Air Conditioner
Is the compressor running when the heater is on?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-21-2005, 10:28 AM
Re: Re: Air Conditioner
No, My Compressor Works Properly.
Old 06-11-2005, 07:10 AM
ctaylor2 ctaylor2 is offline
Hi
Iwas just reading about your problem and I have the same problem with my 2000 S-10 and I am thinging that it is the battery is weak and that it needs to be replaced did you evry find out what was the problem with yours if so i wounld like to know what it was.
Thanks
