Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 04-18-2005, 05:42 PM
CanadianRanger CanadianRanger is offline
Timing Belt
Does anyone know where i can get a good guide to change the timing belt on my buddys 2001 civic 1.7 ex. Thank you
Old 04-18-2005, 05:56 PM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Re: Timing Belt
You have to remove the PS pump, alternator, Crankshaft pulley, Drive belts, etc. It is a long process.
03.IS300.MT.LSD. 'Supra in Training'
Old 04-18-2005, 10:37 PM
BullShifter's Avatar
Re: Re: Timing Belt
There are 2 choices when it comes to manuals, aftermarket & factory. For a timing belt a factory one is not really required because it's pretty straight forward. Most auto parts sell the cheapies Haynes & Chiltons. www.helminc.com for a factory manaul.
You could also go to a Honda dealer and ask if you could get some copies of the pages needed, some will do it & some wont.
My best advice - replace the water pump while your in there!
Cheap Honda parts - http://www.hondaautomotiveparts.com/
Old 05-05-2005, 12:02 AM
koolaid koolaid is offline
heres how to do it
1 . valve cover
2. top timing cover
3. aling timming marks on sprocket
4. drive belts
5. harmonic balancer
6. top driver side motor mount
7. bottom timing cover
8. losen belt adjuster
9. take out timming belt
here is what u need
honda bond
valve cover gasket
recomendations
replace:
water pump
belt adjuster
when putting back the valve cover gaskets put a small ammount of honda bond at each 90 degree bend other wise u will leak oil
takes me just under 2 hours...but for some1 off the street...plan on a all day project
