Old 04-18-2005, 05:33 PM
Hendrock Hendrock is offline
Top dead center
I put my valves at top dead center
but i need to know how to put my crank at top dead center
help please
Old 04-18-2005, 06:46 PM
A. Souphound A. Souphound is offline
Re: Top dead center
help please
To put #1 piston at TDC: Remove the #1 sparkplug. Insert a 1/4" dowel rod in the spark plug hole. Rotate the crankshaft by hand until the dowel rod is at it's highest point. The crankshaft timing mark should be aligned
with the TDC mark. Both #1 intake and exhaust valve rocker arms should be free (not trying to compress the valve).
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 04-19-2005, 08:46 AM
RatLabGuy's Avatar
RatLabGuy RatLabGuy is offline
Send a message via AIM to RatLabGuy
Re: Top dead center
In theor you don't even need teh dowel, just look for the timing mark on the crank pulley to be at 12 oclock.
Although I have a very foggy recolloection that on the 1.9L there was something about linng up a missing pulley tooth with the crank sensor?? So foggy....
Old 04-19-2005, 01:09 PM
Re: Re: Top dead center
could i get a diagram thanx
