Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-18-2005, 04:20 PM
cliff1 cliff1 is offline
2000 Power Window problems
My passenger window will not go up/down, when i hit the window button i hear a clicking from the door module box. Is there a way to test if it is the module or the motor itself is bad. Oh by the way the passenger rear window is now inoperable also.
Thx
Cliff
Old 04-18-2005, 07:57 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: 2000 Power Window problems
More than likely your regulator cable snapped or broke since you can hear the motor moving.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 04-19-2005, 04:02 PM
Thx
Cliff
I'm sorry but the motor is not running
Thx
Cliff1
Old 06-20-2005, 08:00 PM
Keith05 Keith05 is offline
I Have a 2000 Bonneville SE, and it started out that my rear drivers door would not lock with the power on the door, OR the remote.. So after a week, I decided to pull it in the shop and take a look, and noticed that now the only lock/window/mirror that worked, is the drivers door.. So to recap, I ONLY have power mirror/lock and window on my drivers door, no where else... I also here the clicking of the relay under my back seat in the fuse panel... Any help would be GREATLY appreciated..!
Old 06-26-2005, 09:35 AM
dbgmpa8 dbgmpa8 is offline
Re: Re: 2000 Power Window problems
This just happened to our 2000 bonneville. I got the door panel off. Can you give advice how to replace/repair the regulator cable? A diagram would be helpful as well.
TIA - Don
Old 06-28-2005, 03:33 AM
markwb's Avatar
markwb markwb is offline
Cliff, the fact that you hear the clicking is good, that means you have serial comms. I'm assuming the window does not operate from the drivers door or the passenger door, correct? The problem points in the direction of a bad drive motor. The clicking that you hear is power & ground being applied to the motor via the passenger door control module.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
