Old 04-18-2005, 04:07 PM
makaveli3004 makaveli3004 is offline
Adding a 2nd battery
hey currently im running 3 700 watt mmats subs to a 1400.05 mmats classd amp and all 0gauge wire to the battery under the hood. My question is if i add a 2nd battery in the trunk do you think i would get more power or maybe make the subs a little louder??
http://members.cardomain.com/makaveli3004 My 97 Camry
Old 04-18-2005, 04:57 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: Adding a 2nd battery
No, it MIGHT stabilize voltage. But, it will be more stress on your alternator. The proper thing to do is upgrade your alternator. Check out www.sounddomain.com ->forums ->electrical explanations
There are TWO alternator group buys going on at the moment. Excessive Amperage AND Iraggi Alternators...
I myself own a Mean-Green. (www.mean-green.com)
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 04-18-2005, 07:13 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Ditto above./\/\/\/\/\/\
You can't just add a battery and expect it to work with stock alt.. I suggest going with one great gel cel and new alt..
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 04-18-2005, 08:18 PM
ngsm13's Avatar
I have a MINT condition Optima Red top for sale, $90+m actual shipping.
NG
Old 04-20-2005, 11:18 PM
germanyt germanyt is offline
quick question on the subject. when adding a second battery, does there need to be some form of diode between the two or are there not usually any problems with just the straight wire?
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
Old 04-20-2005, 11:20 PM
also, can you have too much output from you alternator or is more better? i was checkin out the mean green 220 amp.
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 04-21-2005, 01:43 AM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
screw wha noah says. run a 2nd battery it will work better then a new alternator. Most of those HO alts still put out the same at and near idle. just connect the two batts directly with 1/0 awg. I'd suggest a optima D31 yellow top.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 04-21-2005, 10:35 AM
ngsm13's Avatar
Re: Re: Adding a 2nd battery
And watch the reliability and the life of your alternator slowly decrease until it shits out on you
NG
PS: Mike hates when I'm right from an electronics standpoint
Old 04-21-2005, 04:18 PM
notladstyle@yahoo. notladstyle@yahoo. is offline
Send a message via AIM to notladstyle@yahoo. Send a message via Yahoo to notladstyle@yahoo.
You have to have some type of battery management hardware to isolate the batteries output currents. If you have hte right equipment a second battery will definitely be better than a HO alternator cuz it will only charge hte second battery when the alt is at high speeds and it will close the circuit at idle keeping the boom from your system from raping your regulator/alt. heres a few links i found right off hte top of google...
http://www.4wdsystems.com.au/html/isolators.htm- this one looks promising but if you drain the second battery you are kinda screwed for audio until it charges.
http://www.geocities.com/harald_nancy/isolator.htm - interesting but I dont think this will handle high current aplications like car audio.
http://www.bcae1.com/battiso.htm - More info on isolators
http://www.mp3car.com/vbulletin/showthread.php?t=44071 - super sized pictures...
But I'd take a yellow top over this crap any day.
Neon Lights add 10hp... per color
It seems my sig pic was too big for some ppl to see on their screens - srry about that
