Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 04-18-2005, 03:00 PM
planktonman planktonman is offline
Clunk Clunk Clunk when braking
1995 Mercury Villager 125K.
When braking there is a knocking noise which reduces in speed as the car slows down. I thought this might be the rotors. I replaced them and the pads (they were pretty worn) but the knocking still occurs. I am thinking it might be the CV joint. Any help given would be greatly appreciated.
Old 04-21-2005, 09:36 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: Clunk Clunk Clunk when braking
all your lugs tight? when i was a teen, i had the same noise on my 76 ford elite. turned out when i changed a flat i didnt tighten the lugs all the way. so when braking the tire would make a load knocking.
Old 04-28-2005, 09:08 AM
ksyankee ksyankee is offline
Send a message via AIM to ksyankee
P, try braking with the emergency brake only to make sure the noise is coming from the front, and have you inspected the rears? Also, check clearance issues as the slow down might be causing something to swing against your driveshaft, wheel, etc. G luck!
Old 05-03-2005, 07:55 PM
IH8SPM's Avatar
IH8SPM IH8SPM is offline
Your rotors may be glazed and or you lower caliper bolt may be missing or loose.
Old 05-01-2006, 07:06 AM
jestersht's Avatar
jestersht jestersht is offline
check the bushings on your front lower control arms and see if there is any play in them becouse they get pretty warn, my van had the same prob but all good now
