Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-18-2005, 01:59 PM
baseballj baseballj is offline
Unhappy Blinker Trouble, please help!
I have 94 olds cutlass cieraand I'm having trouble with my blinkers. My left blinker was stuck in the on position and I found out that the left front bulb was out so I replaced it. No problem so far. This worked for about a week and half and then it started acting up again. This time my left blinker will stick on (the bulb is actually working this time) or blink very intermittently (every 6 or 7 seconds). I can't figure out what is wrong. If anyone has some words of wisdom I would greatly appreciate it. Thanks!
Old 04-18-2005, 08:26 PM
Mrbizness1 Mrbizness1 is offline
Re: Blinker Trouble, please help!
Did you happen to check the rear bulb?
Old 04-18-2005, 09:46 PM
Yep, all the lights come on. The left just won't blink.
Old 04-19-2005, 08:09 PM
Check the wires in the bulb socket for wear, and moisture. It sounds like you have a short someplace
Old 07-28-2009, 07:35 PM
nelson480 nelson480 is offline
replace the turn signal relay, they commonly go bad on cutlasses and GPs, its the white box under the dash and wala! problem solved!!
