89 TA no power
Have 89 T/A. Car has 200,000 miles on it.
Car idles fine but will not go over 30 MPH. When I press the gas the car just boggs down. Have replaced the wires, plugs, cap, rotor. also have added fuel injector cleaner and octane booster None of these attempts have helped. The car does burn some oil, blue smoke out of exhaust I wanted to check the timing but not sure what to set it for. Looking in the Chiltons manual it says to set a 1989 engine code E to 6B (Before Top Dead Center) the vehicle control label on the bottom of the hood says to set it to 0 DR. Not sure what DR stands. If it runs good at idle could it be timing? If so, what should I set it at. Also attempted to change the gas filter but the bolts are rusted on and I'm worried I may crimp the fuel lines trying to get it off. Also for some reason my fuel guage is now pegged at the Full mark Any other ideas on what the problem may be? |
Re: 89 TA no power
Welcome to the forum and have your scanned for codes?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
Engline light does not come on
Re: 89 TA no power
Just cause your light isn't on doesn't mean there aren't any code being held in the ECM.
Ok I will check for codes. Thanks for responses.
Do you know what 0 DR stands for? Would like to try to time my TA, it is 1989 5.0L 305 Thanks again for your time! Nice site! |
Re: 89 TA no power
Hello, first off, blue smoke means you are burning to much gas, black smoke and you burn oil, white smoke, here goes water... Now did the car run fine BEFORE you changed all those things, or was it an attempt to fix the situation? |
Re: 89 TA no power
also, because ou mentioned the blue smoke, you might be getting way to much fuel into the combustion chamber, which will slow you down, dramatically if the air/fuel ratio is way off. on top of my head I'd say ignition/timing off, or a fuel delivery problem, ...
Re: 89 TA no power
buy a carb car. much easier ;-)
sounds like way to much fuel to me. have you changed injectors or anything like that lately.
http://members.cardomain.com/jm9301 It runs once more. Parked for winter. |
Re: 89 TA no power
200,000 miles might be the issue, Why is it when my car is richer than piss, the smoke is black. When I sneeze a turbocharger, the oil is dumped directly into my intake manifold and I burn blue smoke? When I sneezed a head gasket, it was pressurizing my oil sump and pushing oil into my intake and burning blue smoke
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
Re: Re: 89 TA no power
don't know, you must have a real special car...., blue is gas, black is oil and white is water, you'll find that info pretty much everywhere... |
Re: 89 TA no power
Bad fuel mixture is a good guess, especially since the exhaust smelled REALLY rich when I stopped over. -Marty
