Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 04-18-2005, 11:58 AM
srsnyder srsnyder is offline
Starter motor problem?
2000 Jeep wrangler was running fine, went to start, heard a slight poping noise, starter would not turn over. I noted that when I turned the key forward, the guages indicated power from the battery, gas in the tank, temp normal, etc. When I attempted to start, I would hear a click (relay switch), the starter did not turn over, and I would lose power.
So, Plenty of juice from the battery, no issues with fuses, relay switch clicks when the key is turned, and I was able to start the Jeep by popping the cluth after a push, runs without difficulty but won't start when turned off. Also, I noticed that the clock on teh radio reset itself, which I found odd. Sound like the starter to you?
Next Q, I'm considering changing the starter myself, as I have the time. I changed a few starter motors back in my youth, and figure that it shouldn't be too much of an issue now. Anything I should be concerned about with the 2000 jeep?
Thanks for any help!
S
Old 04-18-2005, 12:46 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Starter motor problem?
I'd test voltage on your battery first with a loadmeter -- especially if it's the original one. The problem you described could be the battery.
I wouldn't rule out some relay somewhere either.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 04-18-2005, 03:26 PM
CanaMark CanaMark is offline
Replacing the starter motor, is an easy job. Just remember to hit a store to pick up a 6-pack of labatt Blue
Old 04-18-2005, 03:32 PM
Beer required!
Old 04-24-2005, 03:11 AM
eh!!!!!
