Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-18-2005, 09:17 AM
msikdm's Avatar
msikdm msikdm is offline
right side engine knock...suggestions
Hello All,
Have lurked for some time... very informative board.
I have a 98 3.2L 138,000 miles. Great vehicle and i have
spent very little money considering age and mileage. Mostly general
maintanence.
At 90,000 miles had the timing belt and tensioner changed and
got suckered into purchasing a new EGR (dealership told me it needed
to be replaced) hard pinging ...I now know better
Somewhere about 10,000 to 15,000 miles ago i noticed a knock
right engine compartment always at about 2000 RPM or on hard acceleration... let off the accelerator noise goes away. After researching the board sounds as though i may have a bad tensioner.
Question...Should i get more mileage and age from this timing belt and tensioner. Job completed by an Isuzu dealership (06/2003) and i assume OEM parts were used.
thanks
msikdm
Old 04-18-2005, 09:58 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: right side engine knock...suggestions
how is your oil useage?
and yes you should get at least another 90K out of your tensor.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 04-18-2005, 10:08 AM
msikdm's Avatar
Re: Re: right side engine knock...suggestions
Oil usage is stable. I change the oil at 3 to 4k and check with every
fillup. Maybe add a half quart after a really hard road trip. Used to drink more oil before i realized i needed to change the PCV and clean EGR. I have used full synthetic since day 1. Probably a waste of money
with the milage i now have.
thanks
msikdm
Old 05-01-2005, 03:21 AM
Jovian9 Jovian9 is offline
Same problem here....b/t 2000 & 2500 RPM's. Though I was told at one shop that it could be my catalytic converter starting to break up.....or that my exhaust pipes could be double pipes and the inside could be coming apart. But that really doesn't make sense b/c it only happens when I'm pressing the gas and it is b/t 2k & 3k RPM's. Though this was not an Isuzu shop telling me this.
Old 05-05-2005, 08:04 AM
msikdm's Avatar
re:right side engine knock...suggestions
Maybe a "knock" is not the best descriptor of the sound i hear.
It is most difficult to describe ... kind of a metallic tapping-grinding-growling sound...
Sounds like my Mum's old sewing machine.
I have also noticed a definite lack of power as well. Most noticeable
on inclines. If i have come to a stop or slowed down before reaching
an incline i can feel loss of power while making the incline. Really have to goose it up the hill. And the noise that i have mentioned is most horrible at that time.
Had a tune up at 90,000 also : with plugs and wires that Isuzu suggested. Was rather expensive
thanks
msikdm
Old 05-19-2005, 04:53 PM
rebuild_king rebuild_king is offline
its rocker arms look into atf fluid or light weight oils
