Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-18-2005, 10:13 AM
blackbonnie blackbonnie is offline
2001 door panel removal info needed
I have a 2001 SLE that has a rear window and a driver side window that will not go up or down. Sounds like a relay clicks when you move the switch but no motor noise on the front window. The rear window has a cable laying in the bottom of it and the motor does operate. I was able to get that panel off but I am confused as to how the clips in the center of the panel are to be released. Luckily they didn't break, but I am wondering what the correct procedure is for getting them to release before I tackle the front driver side door panel. Any help with any of my problems would be greatly appreciated. Are Bonnevilles notorious for having lots of window problems? Seems like the topic comes up alot.
Old 04-19-2005, 07:38 PM
cliff1 cliff1 is offline
Re: 2001 door panel removal info needed
My 2000 has the same problem but on the passenger side. All i get is a clicking sound in the door module. As for your question about the clips in the center of the panel you have to pull up on the panel, as the clips are on a slide clip. To reinstall you need to take the clips off of the panel and install on the door and then reattach the panel.
Good luck and let me know how you make out
Thx Cliff1
Old 04-23-2005, 12:53 PM
markwb's Avatar
markwb markwb is offline
Yes, as you remove the interior door panels once all the fasteners (perimiter) are loose, remove panel in an upward direction to release those clips. The drive motor assemblies on these cars are notorious for failing especially the cables. Also, when re-installing the water deflectors, make sure you get a good seal. You may have to renew the butyl seal adhesive.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
