Old 04-18-2005, 08:39 AM
joel poulson joel poulson is offline
heater fam control
hi, me again, got another problem, 99 alero, hte fan spped control is dead on all speeds except high, i have replaced both the swith and fan, does anybody have any other ideas, thanks
Old 04-18-2005, 07:04 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: heater fam control
Most likely the infamous fan blower motor resistor. roughly a 30 $ part - should take about 1/2 hour to change.
Old 04-20-2005, 11:09 PM
jr6078 jr6078 is offline
Ridenour's right. The blower motor resistor is most likely your problem. First remove the plastic panel right below the glove box, then follow these instructions that I got from www.Alero.org.
The resistor is located next to the firewall on the passenger side. It is in part of the blower motor plastic housing assembly, on the downside part of the assembly that is toward the passenger's feet.
To get to it, you will need a 7/32" socket and a universal socket adapter. It helps if you have skinny arms, but you will need to open the passenger door, and lay with your upper torso on the passenger floor.
Look up toward the fire wall and you should see wires feeding the resistor via a connector. You will see two bolts holding the resistor in the housing.
Old 06-20-2005, 01:07 AM
sirius sirius is offline
I would just like to say that you guys are awsome!
