| Off-Topic Talk about anything other than cars. |
bent valves?
ok i think i have bent valves, but i dont and never hurd and knocks, ticks, or clanks of any kind. wouldnt i hear something if i had bent valves?
Re: bent valves?
what makes you think you have bent valves? Give us the symptoms of your car and put the make and model plus and mods in your sig so we know what you are driving.
2000 Chevy Silverado 1500 4x4 Extended Cab. 1996 Pontiac Sunfire GT 5 Spd. 1992 Plymouth Laser RST AWD 5 Spd. |
Re: bent valves?
well hope you dont have bent valves cause then you have to replace the engine or rebuild it. but more info is needed to help, Thanks.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black) Stock 93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red) Cosmo Racing Air Filter Brembo Rotors 14b turbo Faze Boost Gauge Faze Air/Fuel Gauge Dual Gauge Pod Megan Racing 3" turbo back exhaust 450cc Injectors I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested |
Re: bent valves?
if you bent the valves its not the end of the world. if you cracked the valve guides you could have warped the head. do a compression check.
you'd only bend the valves if your timing marks were off. were you messing around with the timing belt, cams??
DSM geek |
its a 95 tsi awd and yes i was doing the water pump timing belt and all the other good stuff. i did a compression test and 0 came up. if the timing was off someting should show up on the gauge right. not just 0. but then again like i said befor i never hurd ant clanks or anything. i really dont want to pull the head just to check.
Re: bent valves?
0 compression could be lots of things. it could be bad rings, bent valves, head gasket or lots of others. if you bent the valves you may or may not have heard anything. your timing has to be perfect or damn near for the car to run. if the timing was off you probably did bend some valves. the only way to check is to pull the head and take it in.
Re: bent valves?
It your valves are screwed, as gthompson97 above me posted, your car won't run. If you want to narrow down options, try a leakdown test.
I used to own a DSM. Quote:
i want ahead and said fuck it and pulled the head anyways and sure enough i have bent valves. now i have to get a rebuild andSHOULD be back on the road. just thought i would inlighten every1. thanks for every1s help.
