Old 04-18-2005, 12:19 AM
firedemonlord89 firedemonlord89 is offline
Send a message via AIM to firedemonlord89
Exclamation mitsubishi bads rep
hey guys i was having some trouble about deciding which car to get and it all ened up on the quality of the car
i heard alot of things that mitsubishi engines has a bad rep of being reliable. i have my own eclipse and its still running good but i've heard alot of bad things and dats y mitsubishi has a good warrenty
can snyone tell me some of the bad rep it has
thank u
96 Eclipse GS
Red Underbody glow kit
Cold air intake
NGK Iridium IX spark plugs
trust high flow cat
trust 4.5 muffler
Ebiach 1.75 drop springs
BBS crome rims (5spoke)
Old 04-18-2005, 12:39 AM
Eclipsewhipping Eclipsewhipping is offline
Re: mitsubishi bads rep
CRANKWALK! thats the only major problem ive heard about wit a mistubishi engine. o and a problem not directed to engine but on 96-97 spyders the convertible top can easily get messed up because the supports arent strong enough,
Old 04-18-2005, 01:09 AM
silver98GST silver98GST is offline
Re: Re: mitsubishi bads rep
Crankwalk is something people talk about when they talk about DSMs, but it is a rare occurance. Can't really think of anything bad. Hmm...well, if you get a turbocharged DSM then you'll most likely develop an addiction for the car. Oh, and your gf/ significant other may become jealous when you start spending more time with the car and calling it baby. Sorry, got off topic at the end. You shouldn't have reliability issues if you keep up with the maintenance/ tune-ups.
1998 Eclipse GST AT
Mods: FP intake pipe, K&N filter, MBC, Glowshift pillar pod w/ tinted gauges (boost, A/F, oil temp gauges), Blitz DTT DC2 turbo timer, Greddy Type S BOV, Apexi N1 exhaust, Megan downpipe, Dejontool blow thru UICP, GM MAFT, Denso 660cc injectors, ARP headstuds, 3000gt sl big brake upgrade, Eprom ecu, DSMlink V2, etc.
Come visit my cardomain page!
Old 04-18-2005, 01:37 AM
what is a DSM ?
Old 04-18-2005, 02:00 AM
Originally Posted by firedemonlord89
what is a DSM ?
DSM stands for Diamond Star Motors. DSM cars are 1g/2g Mitsubishi Eclipse, Eagle Talon, and Plymouth Laser. You can learn more about them by searching on this site, or go to www.vfaq.com Which Mitsubishi car are you interesting in purchasing?
1998 Eclipse GST AT
Old 04-18-2005, 02:28 AM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
(nice car) silvergst sorry that was off topic but I have a 97 gsx and it has 150xxx miles on it and runs good still i havent had any real bad problems with it and i still have the stock turbo. So i would say that they are fine
Old 04-18-2005, 09:35 PM
macder macder is offline
Send a message via MSN to macder
I think the real problem with mitsu's 4g63 is that most mechanics don't know how to work on them. So basically many mechanics screw things up giving it a bad rep. Due to this, many shops around the GTA (Greater Toronto Area) refuse to work on these motors.
I regularly service my car which has 270 xxxkm (~168 750miles) and run's great. Doesn't burn or leak oil. Remember, high output usually means high maintenace. Trust me, i've seen GSR motors done after 80 000km due to improper maintenace.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 04-18-2005, 10:03 PM
travis712 travis712 is offline
Send a message via AIM to travis712
What maintence did you do/they not do? Ok, change oil, flush radiator every 65/76000 miles, tranny oil, spark plugs if they show corrosion or any faults, and thats all I can think of. Did he not do ANY of these? 80,000 miles sounds like a short freaking life man.
Old 04-19-2005, 03:05 PM
Prime First's Avatar
Prime First Prime First is offline
Send a message via AIM to Prime First
I agree on this. A lot of Japanese engines are kinda complicated for those that don't know what they're doing. They're not as primal as some others...
Prime First
1999 Mitsubishi Eclipse
10th Anniversary Edition
