Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-17-2005, 11:32 PM
takiraj takiraj is offline
94 Camry Check Engine Light! Need Help!!
My 94 Camry check engine light has just come on recently. I've never seen it on until now and I don't know why. The car has 148k miles on it, what could be the problem? I have tried checking the code myself using the paperclip method that I found on this site, but could not get anything out of it. The light just stays on and does not blink once. How can I check the code? Is there a reset button or anything I can do? Any help is appreciated. TIA.
Old 04-18-2005, 12:06 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 94 Camry Check Engine Light! Need Help!!
Welcome to the AF.
Your car maybe OBDII compliant which means you need a code reader. Check on the label attached to the underside of your hood. See if it says OBDII certified.
http://www.iequus.com/assets/manuals/3100E.pdf
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-18-2005, 02:27 AM
Can I purchase a reader at any autoshop? How much are they?
Old 04-18-2005, 08:19 AM
Brian R.'s Avatar
Resident Chemist
I believe you need an adapter that is specific for Toyota. Any reader will work with the appropriate adapter. I have had trouble finding the right adapter at my local stores. I think online is the best place to buy one.
I think prices are $100 on up. One that monitors engine functions is particularly useful - feeds data into computer like notebook or hand-held pc.
If you live near an Autozone store, they will check it for free.
Old 04-18-2005, 01:28 PM
Re: Re: 94 Camry Check Engine Light! Need Help!!
I went to a Autozone store and they said that they could only do 96 and up. Is that true? I think the guy was just being an ass.
Old 04-18-2005, 01:48 PM
Brian R.'s Avatar
Resident Chemist
1996 and later cars have to be OBDII compliant. Toyota made some of their 1994 and 1995 cars to be OBDII compliant. If your car is, then point it out to him and they should check it.
Check your emissions sticker under the hood. It will tell you the story.
Old 04-18-2005, 02:05 PM
I'll check it out again. Thanks for a timely reply.
Old 04-18-2005, 03:04 PM
Re: Re: Re: 94 Camry Check Engine Light! Need Help!!
I called Autozone to make sure because its quite a distance from my location and i mentioned that it was OBDII compliant. He said he still couldn't check it, that it had to be 96 and up. I guess I'll just take it to the Toyota dealer.
Old 09-30-2005, 07:04 AM
Mrjackalope Mrjackalope is offline
Re: Re: Re: Re: 94 Camry Check Engine Light! Need Help!!
I just had my 1994 CAmry checked at Autozone. 1994 Toyota's 6-cyl made in Japan models have three OBD connectors. One under the dash that is circular, one onder the hood and a hidden OBD-II connector behind the storage compartment/fuse box. This is located left of the steering wheel and below the A/C vent. Open the door and squeeze the tray to take the door out.
