Old 04-17-2005, 10:08 PM
81firebird 81firebird is offline
Car has no power!
I recently rebuilt my motor and finally got it running a few days ago. It idles great and all but when i go to give it some gas for hard acceleration the rpms just flatten out and i cant even get the tires chirpin. Im wonderin if my cam is too big for my carb and its not gettin enough fuel or if my torque convertor is dead. Any ideas?
Old 04-17-2005, 10:41 PM
Thumprkils's Avatar
Thumprkils Thumprkils is offline
Banned
Send a message via Yahoo to Thumprkils
Re: Car has no power!
large cams can often cause vaccum loss. if so just down size, is this when you try to start off real fast it wants to bogg down real bad, does it idle real well in neutral?
Old 04-17-2005, 10:59 PM
it doesnt bog down, it just seems to climb slowly until a certain point then just hold there even if i have my ffot to the floor. And it idles fine in neutral
Old 04-18-2005, 06:16 AM
volkerc's Avatar
volkerc volkerc is offline
Re: Re: Car has no power!
has nothing to do with engine vacuum. i assume you don't run to large a cam anyways. sounds like your carb needs to be checked. what brand of carb are you running? Holley? 4 barrel or 2 barrel? sometimes the secondaries do not open wide enough cause of bent or improperly adjusted linkage. depending on the specs of your engine the metering jets in the carb might need adjustment (replaced to correct size). if it climbs slowly you might actually be getting to much gas, which will slow you down. you need to have the correct or as close as possible to correct air fuel ratio to get the most out of your engine.in order to give better advice the following info would be helpful. size engine, size cam, size and manufacturer of carb, ignition set at what degree?
Old 04-18-2005, 09:40 AM
Thumprkils's Avatar
Banned
volkswagonman he says (if youd read more than one sentence) that his cam might be to big
and yes a large cam can cause a vac problem
but it could be something else , maybe a q jet instead of a holley if he has a holley
Old 04-18-2005, 10:32 AM
Ive got a chevy 267ci with a rochester dualjet 210. The cam is comp cams part # 12-238-2 http://www.compcams.com/Technical/Se...umber=12-238-2 and my ignition is set at 11 degrees
Old 04-18-2005, 02:55 PM
volkerc's Avatar
ok,
looks like i was correct, from the info I found about your carb, it seems that you have a 2 barrel carb, so your carb and intake is restricting the power the engine could now make. I currently have a similar cam in my 350 Pontiac, but it has all the mods.Your engine lacks the ability to suck in the air, try to run the olympics breathing through a straw.pretty much the same thing. Your timing is ok, the carb is not.Am I correct in assuming that you just put in a bigger cam than stock without any other mods?
Old 04-18-2005, 03:22 PM
volkerc's Avatar
Insulting me again dumbklit? or what was your name, I don't know, cause I do not read full sentences!
Old 04-18-2005, 10:49 PM
ya i just put in a bigger cam when i did a rebuild. I also got the carb rebuilt.
Old 04-19-2005, 01:12 AM
volkerc's Avatar
so, that did not help you at all, with that cam you need headers and a new intake together with a better carb, 4 barrel, but the carb can't be to big either, probably less than 600 cfm is what you need.you could get some good used pieces to stay in a budget. once you change those things your car will be as you wanted it to be.just putting in the cam would not do anything, it actually went the other way...
Old 04-23-2005, 08:11 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
hows the exhaust a pluged exhaust can make the car run funny
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 04-24-2005, 11:28 AM
volkerc's Avatar
the problem was already solved. he only put in a bigger cam without any other mods.
